> bumpers on 75/76 cars, older bumpers mounted on newer cars
whaletailcanada
post Sep 29 2005, 02:35 PM
Has any one out there tried to mount older metal bumpers on later rubber bumper cars we are doing a 914 6 project on a rust free late car that had the late stlye bumpers any thoughts or help? Randy
Allan
post Sep 29 2005, 02:42 PM
Teenerless Weenie
Yep, just did mine.
Old
Allan
post Sep 29 2005, 02:43 PM
Teenerless Weenie
New
Dave_Darling
post Sep 29 2005, 05:22 PM
914 Idiot
Show him the tabs you had to cut off. There's one on each side of each bumper; they're where the bumper cover hooked onto. Also the front lip of the channel where the front trunk seal goes is taller, you need to deal with that (cut it or remove/replace it).
The reinforcements for the bumper mounts should already be present in the front fenders; not sure about the rear trunk. The rear bumper mounting bolts have the upper two in the trunk, and the lower two below the trunk floor.
--DD
MoveQik
post Sep 29 2005, 05:24 PM
What size wheels can I fit?
QUOTE (whaletailcanada @ Sep 29 2005, 12:35 PM)
See my blog. I did it. You have to cut off these tabs and the lip that runs right below the front trunk lid. Easy swap to do.
Allan
post Sep 29 2005, 05:25 PM
Teenerless Weenie
front tabs. 1 on each side.
Allan
Teenerless Weenie
oops
MoveQik
post Sep 29 2005, 05:26 PM
QUOTE (Headrage @ Sep 29 2005, 03:25 PM)
Oh yeah...those too!
Allan
Teenerless Weenie
And this channel needs to be cut back.
Allan
post Sep 29 2005, 05:27 PM
Teenerless Weenie
Same on the rear.
MoveQik
I just drilled the spot welds enough to pop them off and then smoothed everything out. No need to drill all the way through.
Allan
post Sep 29 2005, 05:31 PM
Teenerless Weenie
Then ya gotta plug these hole so water doesn't get in the trunk. I'm going to use the shock retainers as a template and make some plugs in case somebody down the road wants to go back to original.
sixnotfour
post Sep 29 2005, 05:57 PM
FYI; If you go with fiberglass bumpers the front edge /channel supports the top edge of the bumper nicely.
RustyWa
post Sep 30 2005, 01:28 PM
Working Member
QUOTE (sixnotfour @ Sep 29 2005, 04:57 PM)
That's sweet to know. If you went with fiberglass, do you think you could get by with not having to remove the tabs on the sides? If needed could you modify the fiberglass to fit around them without it looking like you modified the bumper?
- Lo-Fi Version Time is now: 26th December 2024 - 07:45 AM
