Wrist Pin Etching, useable or no? |
McMark |
Oct 1 2005, 07:35 PM
I have these wrist pins for a stock 2.0 six cylinder motor. Most of them have a slight etching to them. I'm not sure of the history of the motor so I don't know what might have caused it. I suspect water. Does anyone know what might have caused this? Should I continue to look for replacement wrist pins? Or use these? They can be slightly felt with a fingernail.
Attached thumbnail(s) |
MartyYeoman |
Oct 1 2005, 07:39 PM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Keep looking for a flawless set.
I have ruined a rebuild in the past due to a wrist pin failure. |
McMark |
Oct 1 2005, 07:44 PM
Yeah, I know/knew what the answer was, but just thought I'd check. Kind of a wishful-thinking post. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Twystd1 |
Oct 1 2005, 08:06 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
Could it be from water/moisture acting as as an electrolyte and the two dissimilar metals acting as an anode and a cathode? (Tool Steel VS Aluminum?)
This kinda makes a battery of sorts. Usually the aluminum turns to shit first as it breaks down faster. The wrist pin damage could be from this galvanic action. Ive seen that before. I just can't remember what the hell the outcome of the research was... JeeZzz i'm getting old... Twystd1 |
Lo-Fi Version | Time is now: 26th June 2024 - 10:28 AM |
