nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
hi all
i've discovered a weird ignition/fuel system quirk in my '75 2.0, which has probably been going on since i've owned it (3 months) -- just haven't noticed it. the engine has a flatspot at ~4600rpm -- it feels like the fuel cuts in and out to keep the engine below this speed. now, i can 'break through' it in 1st --> 3rd gear, it just pauses and stumbles a bit at 4600, then moves merrily along toward redline. but in 4th (and 5th, i presume), it feels like i don't have enough power/momentum to 'break through it'. 2 months ago, car had a full tune up, valves adjusted, etc. airpump removed, air injector jets plugged. aside from this quirk, it runs smoothly and strong. does anyone have suggestions for things to check? (IMG:style_emoticons/default/confused24.gif) nathan |
RustyWa |
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 ![]() |
Nathan,
I had a problem recently where I had a stumble during acceleration. It turned out to be my TPS. I got a new one from European Automotive Specialists www.europeanautomotive.com for $85. Cured the stumble. For testing, I've heard you can disconnect the TPS and see if that cures your problem. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,714 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
uhm, do you have a rev-limiter? hmmm, that would shut off in all gears tho. i threw mine out a while ago ...
Andy |
nebreitling |
QUOTE(SirAndy @ Aug 7 2003, 05:21 PM) uhm, do you have a rev-limiter? hmmm, that would shut off in all gears tho. i threw mine out a while ago ... Andy i don't know -- where would i find the rev-limiter? (IMG:style_emoticons/default/smilie_flagge6.gif) |
Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
I second the throttle position sensor. Remove the throttle body, remove the cover off of the TPS and clean out all the gunk out inside. If there isn't major wear (grooves in the contacts) then it might work better once clean... of not, then replace.
Cleaning out tons of gooped up oil helped my '74 1.8L run better! Karl |
nebreitling |
QUOTE(RustyWa @ Aug 7 2003, 05:20 PM) For testing, I've heard you can disconnect the TPS and see if that cures your problem. TPS = ? TemPerature Sensor? if so, did you replace the Cylinder Head Temperature Sensor (Temp Sensor II) or the Temperature Sensor I? or perhaps it's the Throttle Switch? (i'm thinking Throttle Position Switch, TPS?) if so, $85 is a good deal (IMG:style_emoticons/default/clap56.gif) thanks, gentlemen |
nebreitling |
whoops, never mind!!
nebreitling |
über-cool
will check out the status of my TPS. this site rocks (IMG:style_emoticons/default/aktion035.gif) |
Howard |
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None ![]() ![]() ![]() |
What a great group. And psychic! I was just about to post the same question about my 73 2.0. Have ordered the DIY manuals but not here yet. Where is the TPS and how can it be bypassed for testing?
Qarl |
nebreitling |
QUOTE(Howard @ Aug 7 2003, 06:17 PM) What a great group. And psychic! I was just about to post the same question about my 73 2.0. Have ordered the DIY manuals but not here yet. Where is the TPS and how can it be bypassed for testing? follow the accelerator cable to the intake and you'll find it. it has some electrical connections and is adjusted on two screws. i have no idea how this could be bypassed (IMG:style_emoticons/default/confused24.gif) anyone and, WELCOME!!! (IMG:style_emoticons/default/beerchug.gif) looks like this Attached image(s) ![]() |
SirAndy |
QUOTE(nebreitling @ Aug 7 2003, 06:43 PM) i don't know -- where would i find the rev-limiter? (IMG:style_emoticons/default/smilie_flagge6.gif) you'll find it inside the dizzy. if you have a rev-limiter, the rotor will have a little spring built in that shuts off the ingnition at a certain RPM ... but again, that would affect any gear. but it can't hurt to check anyways ... Andy |
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
QUOTE(nebreitling @ Aug 7 2003, 06:24 PM) i have no idea how this could be bypassed (IMG:style_emoticons/default/confused24.gif) anyone If you're talking about the TPS, you just unplug it. If you're talking about a rev-limiting rotor (in the distributor) you can't bypass it - you have to live with it or get a new rotor (a non-rev-limiting rotor is just a few bucks). -Ben ps - If you're wondering how to tell between a rev-limiting rotor and a non-revlimiting rotor: Haynes manual has pictures of both. Maybe someone will post. |
nebreitling |
oh.... (IMG:style_emoticons/default/blink.gif)
i need to read up more on my djet -- i thought that unplugging the throttle position valve would cause the FI not to run properly. so what in hell does the tps do, then? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/beerchug.gif) |
Howard |
Again, thanks everybody. I pulled the TPS plug and it helped but didn't cure. Car had been sitting for quite a while..I just bought it 2 weeks ago. Put Techron in the first tank and probably just loosened up some junk. Tank has rust particles inside and will drain and get it hot tanked or replaced as necessary. And another neat thing. Car floods and will not start when cold start injector is connected. Pull plug on that and it starts on first kick. I think it just needs an enema.
Howard |
kellzey (thanks Karl) sent me to this page about the TPS. Check it out
Attached File(s) ![]() |
airsix |
QUOTE(nebreitling @ Aug 7 2003, 08:34 PM) oh.... (IMG:style_emoticons/default/blink.gif) i need to read up more on my djet -- i thought that unplugging the throttle position valve would cause the FI not to run properly. so what in hell does the tps do, then? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/beerchug.gif) It won't run properly. You don't want to drive around without the TPS working - you won't have any accel enrichment (like a accel valve on a carb that squirts extra fuel when you quickly press the throttle). Unplugging it is just a way of testing to see if it's at fault - if at fault it'll send weird signals most often resulting in slight surging or bucking when driving at a steady speed. -Ben M. (ps - I don't think the problem is the TPS but I could be wrong) |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Howard. You live in a warm climate. Leave your cold start valve disconnected. I leave mind disconnected year round. It shouldn't get cold enough there to cause the cold start valve to activate anyway, so the fact that yours seems to be getting activated indicates that the temperature sensor that controls the cold start valve is defective.
Demick |
Howard |
Demick. Thanks, I have reached the same conclusion. Wind chill here got down to 66 last night.
But something is wrong. Advise pulling all out to clean? Put in a new fuel filter and assume that will trap most of the gunk. |
Anton |
Royal Orange ![]() ![]() Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 ![]() |
IMPO these things mostly come down to a maintenance deficit.
Your car had a "full tune-up" but does that include: - New FI trigger points? A very likely candidate for your problem BTW. - Fuel pressure check? Important determinant of FI system function. - Fuel injector clean-up? Check on a test bence and clean ultrasonically and/or replace where needed. - New condenser? Sould be routinely exchanged every couple of years. - Vacuum hose check up and/or renewal? Vacuum leaks are infamous for all sorts of engine trouble. When these measures don't work out go for the pressure sensor, TPS, sticky distributor plate (!), etc. There are various manuals on the web on D-jet trouble shooting. I believe there is one on the PP website and here is what Mittelmotor says (eat your heart out; it's in German (IMG:style_emoticons/default/laugh.gif) ). -------------------------------------------------------------------------------- Ruckeln im 914 Die drei wichtigsten Teile der Einspritzung sind der Druckfühler, die Auslösekontakte und der Drosselklappenschalter. Die Funktionsfähigkeit dieser drei Bauteile beeinflußt ganz erheblich die Laufkultur und den Benzinverbrauch des Motors. Wer nicht die Möglichkeit hat, die Funktion dieser Teile zu messen, sollte auf folgende Symptome seines Motors achten: defekter Druckfühler: - starkes Ruckeln bei konstantem Gas - hoher Benzinverbrauch - Leistungsmangel defekte Auslösekontakte: - Aussetzer nur bei warmem Motor - Heißstartschwierigkeiten - Leistungsmangel defekter Drosselklappenschalter: - leichtes Ruckeln bei konstantem Gas - Beschleunigungsloch bei plötzlichem Gasgeben -------------------------------------------------------------------------------- Anyway, they name three candidates for your problem: the pressure sensor, FI trigger points, and the TPS. Good luck. |
Lo-Fi Version | Time is now: 2nd July 2024 - 09:44 AM |
