Where to run the hoses |
guiltless |
Oct 5 2005, 02:38 PM
Member Group: Members Posts: 187 Joined: 7-August 05 From: Dana Point Ca Member No.: 4,552 |
I have seen a few different ways to run hoses on a car that is using a front mount radiator.
I really have no desire to run copper piping through the cab of the car so that is out of the question. I have also seen alot of people running the rubber hoses under the car and down the center. I am sure that it is a great way, but it scares me a bit, especicaly when speed bumps come around. Is it possible to run the hoses through the center channel of the car? |
dmenche914 |
Oct 5 2005, 02:52 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
No way any cooling hoses would fit int he center tunnel, plus you have a moving shift rod to contend with, too tight. What alot of folks do is run metal pipes under the car on each side of the center tunnel (there is a depression in the floor pan underside on both sides of the tunnel. i have seen galvanized pipe used, maybe it was 1 1/2 inch diameter i think, and i have also seen flat rectangular steeel tubing used, with the ends tappered to a round pipe to allow the hoses to clamp on. these metal pipes will tuck intot he depression, they stick down a little bit, but you basically are hitting bottom anyway by the time you hit the pipes. By using steel, you will not crush them, and be fine (copper would more likely dent or crush).
Do NOT run rubber hoses under the car, as hitting them with somthing sharp will rip them. good rubber hose is more money per foot than steel pipe, it will need to be replaced form aging if not torn first, and the steel pipe will aid cooling as it will radiate much more heat than a rubber hose. Never run rubber hoses in the cockpit, like mine were thru the heater pipes, and up behind the speaker grills. A leaky hose burned my foot, hot anti freeze is not to be in the cockpit in a rubber hose unless you can complety shield the folks inside from a pressurized leak spraying out. i really think under the car, down the middle on either side of the tunnel using steel round or rectangular tubing is the best bet. The rectangular is more money and work, but will gain you maybe 1/2 inch more ground clearance, but either are very good options. |
guiltless |
Oct 5 2005, 02:57 PM
That is EXACTLY what I was looking for.
Thank you very much. |
Crazyhippy |
Oct 5 2005, 03:02 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
I ve driven 35-40 converted cars w/ hoses under the car, and never had a problem cutting them. I have had cars go off track into the baren desert (right rear blowout (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ) hitting rocks and all kinds of stuff, and not cut a hose.
I have also seen motors overheat severly due to running steel pipe under the car, bottoming on a speedbump (i think he drove off a curb backing out of the driveway) and partially crushing the pipe. If you use pipe, be sure it is strong enough to support the weight of the car, rubber hoses bounce back, steel pipes do not. |
dmenche914 |
Oct 5 2005, 03:56 PM
i agree, the tubing to use is thick walled, do not use thin walled stuff like electrical conduit, use plumbing pipe, steel, not cast iron.
banksyinoz |
Oct 5 2005, 06:00 PM
finally getting back into it Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand |
the previouse owner of my 914 has installed a heater in the front and run the hoses through the sill panels its only 1-1/12in plenty of room
Q; when running pipes under the car where do u enter the pipes into front compartment /under tank or through holes infront of the suspension? |
914GT |
Oct 5 2005, 06:43 PM
Senior Member Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
3/4" steel pipe (common black pipe) fits nicely underneath if you want to take the time to bend it so it conforms to the indentations running under the center of the car. It will not crush and I routinely use my floor jack to raise the car under the pipes. I put a short length of 2" square steel tubing to distribute the weight across both pipes. The pipe is bent to aim up into the bottom of the front trunk and can be cut off right under the steering rack. From there you can transition to 1" ID rubber heater hose (Gates or equiv.) to the radiator. The bottom cover under the rack is notched in two places to clearance the pipe.
Attached image(s) |
banksyinoz |
Oct 5 2005, 07:15 PM
thanks now the water pump front or back cut the front and im done there (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Attached File(s) 9141004.zip ( 298.34k ) Number of downloads: 82 |
banksyinoz |
Oct 5 2005, 07:57 PM
forget that pic i worked it out i think (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Attached image(s) |
tyler |
Oct 6 2005, 01:00 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
Lot's of opinions on this. For my 2 cents, I'm just finishing up my system. I used marine exhaust hose, with wire, under the car. It's expensive, but, it's got a nice lining, bends without flatening and I don't think anything ever hitting under the car would cut through it. I ran one piece all the way for both of them - no joints anywhere. On entering the front compartment I have the hoses passing through copper sweat fittings to hold them at 90 degrees against the gas tank bulkhead. Using a Griffin radiator it even cools fine (190) with only one of the 2 pusher fans running. I'll post some pictures tomorrow.
Just a slight setback - the radiator was "seeping" about a tablespoon every 1 hour run, so I just pulled it and sent it back to Griffin. We'll see if they live up to their good reputation. |
tyler |
Oct 6 2005, 01:15 PM
Found some pics of the hoses. This is prior to installing the inlet shrouding & cover plate..........
Attached image(s) |
tyler |
Oct 6 2005, 01:17 PM
My mistake - old pic - try this one............
Attached thumbnail(s) |
tyler |
Oct 6 2005, 01:20 PM
and this.................
tyler |
Oct 6 2005, 01:21 PM
and this...........
tyler |
tyler |
Oct 6 2005, 01:22 PM
well, maybe this one (rushing too much)...........
jsteele22 |
Oct 6 2005, 03:46 PM
Senior Member Group: Members Posts: 727 Joined: 24-August 05 From: Colorado Springs, CO Member No.: 4,653 |
Excellent point. I've been starting to think about plumbing in heat , and was thinking of heat as a luxury, not a hazard ! |
guiltless |
Oct 7 2005, 01:08 AM
Tyler, is that a hole in the front of the car to allow airflow? I was wondering if that could/should be done.
What do other people think about cutting there? It looks like an important support place for the car, but I could be wrong if people are cutting it away. |
tyler |
Oct 7 2005, 07:56 AM
Yes, that's the air inlet which now has ducting to the fans, an air scoop and a protective screen. I really wanted to have an inlet in the middle of the bumper, where the license plate goes so the air would go straight in but that's not an easy cut. As it turns out, cooling works fine the way it is.
marks914 |
Oct 7 2005, 09:59 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I didnt know Griffin made a dual pass radiator. Was it pricey? I am interested to know how well it works.
Mark |
Lo-Fi Version | Time is now: 4th January 2025 - 06:27 PM |
