Buckeye '73 |
Newbie ![]() Group: Members Posts: 25 Joined: 17-October 05 From: Ohio Member No.: 4,963 ![]() |
So there's this lady in the same building as me right.
And she's one of these "the would bows to me types". She's got a 350Z and yesterday (because it was nice and we both had topless convertables in the parking lot) we start talking about convertables. Turns out that her cars better than mine because it's aerodynamically designed to keep the air off of her. (Which isn't suprising because everything she has is better than everyone elses.... (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) ) Meanwhile, the back of my neck still has frostbite on it and I get to thinking. What if I could retract the rear window? Viola no more deflected air! Anybody ever tried it? Theoritically possible? Bryce |
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
Anything is possible with enough time and money (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
bad idea for a few reasons.....
it's loud, no matter what kind of engine you have (an electric motor does not count (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) you'll get more gas fumes coming into the cabin.... it's loud (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I just re-installed my rear window on Sunday, just the few times I've driven it that way it was too loud...cannot remember if the wind was an issue or not, but I wouldn't do it again.... knock yourself out (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I don't think there's room for the window to slide down along the firewall. The curves in the wall would make that kinda problematical.
And I will second what Mueller said. FUCKIN LOUD!!! My ears rang for a couple of days after driving to work and back with no rear window. (It was while I was replacing the window seal.) --DD |
STL914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest ![]() |
I seem to recall a thread on this same idea a couple of years ago on one of the 914 web sites, not sure which one though.
One of the ideas was to use the rear window from a Honda Del Sol. The overall consensus was that due to the cost to fabricate the framework required to mount the window, the limited amount of available space in the 914 driver's compartment, and the high noise levels from the engine that sits just behind you, that it was not very practicle. But like Bruce says, with enough time and money, anything is possible. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
maybe you should think up something else to impress the lady ...
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Cap'n Krusty |
Window seal? The Cap'n |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
I look at that idea, and you would have to cut into the body at the b-piller in order to lower the glass. A worm gear and window regulator and motor would fit if you run a 4.
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Besides, if you adjust the side window down a little, the wind doesn't go down the back of your neck. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
porschecb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None ![]() |
I do not know what shape your car is in but a rear sliding window would be the last, the last thing I would ever think about doing!!!!!!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Find something else to spend your money on! (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I went as far as to pick up a mechanism from a limo to tinker around with this idea a while back. Then I read a thread about somebody or other who drove without their backglass a few times and said it was wicked loud. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Piss, hadn't thought of that. The whole shebang now serves as a very nice mouse resort in one of my barns. (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Dave_Darling |
Yeah, the adhesive had failed along the bottom of the window, so the sum'bitch was rattling. The butyl adhesive (factory stuff, BTW, complete with the wires in it!) was the "seal" to which I was referring. (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) --DD |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Listen to Mike, Dave and all the rest.....
NOISE!!!!!!!!!!!!!!!!!!!!!!! ALOT OF IT!!!!!!!!!!!!!!!!!!!!!!! |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,163 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Yeah, like ask her which car will be worth more in 30 years. |
neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
For neo914-6:
-I just won a del sol mechanism -I will have alot of space at the firewall with the Audi 2.7 tt -my engine doesn't need air cooling so I will seal the lid -the width will be slightly shortened for tracks -I think it will give a greater sense of open air motoring -and I will want to hear the turbos... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s) ![]() |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Besides, don't all the new cabriolets have a glass "windblocker" to prevent excessive wind noise and buffeting? Seems the 914 was quite ahead of it's time in that function.
sgomes |
Electric Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
exactly! |
Elliot_Cannon |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None ![]() |
I thought the whole idea of going with the top down was so you can feel the wind in your hair. I haven't had my roof on in 8 months. I've driven in the rain with the roof off and like the man said, "you only get wet when you stop".
Cheers, Elliot |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
you could tell her that her Datsun looks like crap with the top up. check with her on the cost to drive, payment+insurance, a year, and when does she get out of her lease?
k |
Lo-Fi Version | Time is now: 1st July 2024 - 04:06 AM |
