> Oil Pumps for T4 Race Motor, Schadeck T4 30mm Full Flow Oil Pump
GBallantine
post Nov 15 2005, 11:01 AM
Anybody out there have any experience in running the Schadeck oil pump in combo with a front mounted oil cooler setup. Can it provide enough pressure to circulate thru the system? Is there any other pumps worth considering? Who sells these pumps?
GB
groot
post Nov 15 2005, 12:07 PM
Dis member
I've heard they work fine... but no personal experience with them.
I'm running a 30mm Melling (not by choice, it's just what was on the engine) and it does fine for a wet sump system... Jake Raby has lots of decent pumps for the type 4 that will work.
I'm converting to a dry sump system, though for the long term.
Jake Raby
post Nov 15 2005, 03:54 PM
Engine Surgeon
I have used my modified Schadek pumps with good results- BUT only if the engine was full flowed with my plumbing changes.. I have had ill results when doing the mod with a sandwich adaptor or oil cooler adaptor and going to a front cooler..
I sell the entire full flow kit, or just the pump (The entire arrangement is only 130 bucks for the standard full flow set)
- Lo-Fi Version Time is now: 5th January 2025 - 03:53 AM
