greg derr |
Newbie ![]() Group: Members Posts: 4 Joined: 26-December 02 Member No.: 15 ![]() |
Winter project. I just bought 1985 911 struts spindles brakes and rotors, do I need any other parts for the conversion on my 73 teener? Thanks. Greg
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
New bearings and seals
check the rotors out you might need new ones new pads Shocks |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Should be good to go with the 73/85 swap.
I agree with the above. Maybe get some new bearings while you're in there and the others are unknown. New strut inserts? Through body bar and weld some u-tabs on your a-arms? DWD sets in and you strip the tub throw the entire car into 13 boxes and set her on jackstands for the next decade?? |
johnmhudson111 |
Member ![]() ![]() Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 ![]() |
Pick up a couple of bail joint pins I destroyed the threads on my orginal pins when I did my struts.
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Mine started with an oil leak. Ended up with a new motor and complete rustoration, then traded everything for a /6 conversion... Good luck... |
pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
While you are at it ...if the budget allows....perhaps a set of turbo tie rods.....and perhaps a 19mm master cylinder....but like i said .....perhaps (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Only 13? I've got at least that many plus most of a backyard shed! I hope to beat the decade though. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:59 AM |
