swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Stripping out the interior to get ready for rustoration. Haynes says remove the bolt and pull it off. Not budging. There doesn't seem to be any clip or retainer on the bushing but before I go reefing on it I thought I'd ask. Soaking with liquid wrench.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
yupp, one bolt, slides right off. except, if you still have the cables attached. gotta take those off first. just a simple clip and they'll come right off as well ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
Rusted to the shaft it is. MMMMmmmm Werk hard you must.MMMmmmm Use the torch you may MMMmmmmmm. Curse the day you bought the car you will .Yes
swl |
torch on nylon bushing, good idea is not. The force you must use.
scotty b |
I have had to do this on 2-3 cars now. What happens is the 25+ yr old bushing gets worn through and the handle rusts to the shaft. Unless of course you have been driving this car and using the brake:unsure: Yeah melting nylon is sweeeeet (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
swl |
I got lucky then. The bushing was intact and the handbrake moved freely. Bad rust in that area though and it had started working its way up the post putting clamping pressure on the bushing. Crow bar in behind while working the handle did the trick.
scotty b |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) The force was strong with you (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) But you never gave in the the torch side (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 05:57 AM |
