toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
Has anyone used steel fuel lines down the tunnel to replace the stock plastic?
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Yep. Common thing to do. Gives peace of mind - and is a good thing to do especially if you move the fuel pump to the front (thereby pressurizing the supply line through the tunnel).
Demick |
smontanaro |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest ![]() |
Also common for 6's? Same idea, just no return line?
Skip |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I would say steel lines is the most common upgrade over plastic.
I used braided SS line, however. KT |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
nope, according to the search function, it's never, ever been done before (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Replacing fuel lines with steel lines, by Clay |
toon1 |
I was looking for that post thanks, he used stainless, is regular steel ok?
Mueller |
depends on your definition of "regular".....I'd use steel fuel line, not something found at the hardware store. Summit Racing has steel fuel line is various sizes. If you don't buy from them, at least order a catalog. |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
A member here started making kits. Don't know the status right now though (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
http://www.914world.com/bbs2/index.php?act=...54&hl=fuel+line I have also bought pre made kits for Jeep CJ's from Inline Tubing and they make an EXCELLENT product. (not for Porches though) BUT They also sell lengths of line and all fittings necessary to make your own. They even sell the "spring wrap" used in OEM applications http://www.inlinetube.com/straight.htm Home page link http://www.inlinetube.com/ |
zymurgist |
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None ![]() |
I used mild steel brake lines in 5/16" for feed and return. 60" down the tunnel and 48" in the engine compartment. I cut the flared ends off at the tank and engine ends, but left the other flares in place and connected the lines via brass fittings at the firewall.
toon1 |
How long have the lines been in the car with that setup?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I know I've said this enough to bore everyone... but return lines make cooler fuel and potentially more HP in CARB'd cars! (at the very least they can help with vapor lock issues.) |
smontanaro |
How's that setup? You're dealing with a pretty much novice here. I've never heard of a carbureted car with a return line. |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
http://www.914world.com/specs/tech_fuelline...f7071cbbf310d4d
I just did this with brake lines from NAPA. $3.49 ea |
maxwelj |
rebuilt member ![]() ![]() Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None ![]() ![]() ![]() |
My original 6 has a return line as well as the supply line. It came that way. I just replaced both lines with Napa 5/16 and 3/8 respectively.
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
I bounced over to the tech write up, looks easy enough with the engine out, could this be done with the engine IN ? How painful would that be to do? Anyone done it and have any tips to share?
zymurgist |
A couple of months. I'm still putting the car back together. (Originally the engine/tranny came out for a clutch job, and I came down with a case of DWD.) |
zymurgist |
I think if you want to replace the lines with the engine in, you'll want to use a coil of aluminum tubing and just uncoil it as you thread it into the tunnel. Somebody on the board (tat2dphreak, maybe?) used aluminum, but I don't know whether the engine was in at the time. |
ottox914 |
Trekkor- where did you get your braided SS lines, was it $$$, (I'd think so) did you run them in the factory location, how'd the project go? More details, please! Photos?
Lo-Fi Version | Time is now: 26th June 2024 - 03:37 AM |
