jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
So as long as I'm replacing the rest of the fuel system, I might as well pick a filter of my choosing...
Fuel pump is located in front (above the steering rack), fuel lines are all AN-6. Now the choice is what fuel filter to put in there? Preferably something with threaded ports instead of barbed fittings. Any suggestions? This will be a fuel injected engine, but will probably never need to flow GOB of fuel as it will be running a warmed over 2.0L. There are those little glass bodied filters at the FLAPS, but I doubt they're really that good. But it is nice to be able to inspect the filter element for gunk... Suggestions? -Josh2 |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
On any injected car I would use the fuel filter from an MFI 911. The filter on it is designed to stop extremely tiny particles from passing through 'cause they would clog the precision built injectors. And it has threaded ports on it already.
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
I have Canton filters on my cars. Both oil and fuel filters. You can get filters with either 1 or 8 micron elements
Attached image(s) ![]() |
rhilgers |
Member ![]() ![]() Group: Members Posts: 75 Joined: 17-July 03 From: Santa Clara CA Member No.: 919 ![]() |
Here is a 2nd for the Canton filters. They went up in price though, about $100 with the AN -6 adapters.
1 micron and its even ok as a prefilter! http://www.pegasusautoracing.com/group.asp...upID=FUELFILCAN -Rich Hilgersom |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,555 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
+1 on the Canton. Spendy but very nicely made.
TimT |
Clay dont abuse your administratorshipdom
I opined about the Canton filters earlier today, and have happened by a pc and checked the thread All of a sudden you jump to the head of the line!! and you posted at exactly the same time I did, after me posting the first response hours earlier, with not a peep from you why not keep that admin pass in check... |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Nice idea, but the MFI filters are threaded on one end to install like an oil filter, and the other end is a hose fitting. You want a CIS fuel filter, but the fittings are metric, and most take a cone design fitting. Some take a banjo fitting on one end, but you still have to deal with metric fittings. AN implies braided SS covered hose, which tends to develop leaks. Be careful out there! The Cap'n |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I got a really nice simple racefule filter with a stone for filtering...at least it looks and feels like stone....
Anyways...you unscrew this filter...take out the stone..wash it with carb cleaner and put it back in...simple...and cheap... rich |
RON S. |
9140430841, FINALLY RUNNING ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States ![]() |
I also run a Canton 1 micron filter, Here's a shot from a couple years back before my engine was installed. The car runs a consistant 50lbs. of fuel pressure all day long. Ron Attached image(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 08:56 PM |
