2.7 oil change & valve adjustment, What parts do I need? |
Allan |
Dec 16 2005, 02:47 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I have a guy flying in tomorrow to swap some carbs and he has offered to adjust my valves and tune the car. What exactly will I need? Upper & lover valve cover gaskets, sump-plate gasket(s), drain plug gasket, oil filter?
Thanks... |
Cap'n Krusty |
Dec 16 2005, 02:55 PM
Valve cover gasket kit. It includes the sump stuff, nuts, and washers. "Turbo" valve covers are nice, too, unless it's a 914/6. If it is, then early SC lower covers are a nice addition. Mahle oil filter. A case of oil. The Cap'n
SLITS |
Dec 16 2005, 03:32 PM
"And a partridge in a pear tree"..................... Hi Allan (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
J P Stein |
Dec 16 2005, 06:30 PM
& a 13mm box end wrench, flat blade screwdriver, & a .004 feeler gauge.
Allan |
Dec 16 2005, 07:23 PM
What's the deal with the special "must have" curved feeler gauge that Pelican sells? |
SLITS |
Dec 16 2005, 07:24 PM
Makes it a shitpile easier to get the feeler where it needs to be.....or so I'm told |
ejm |
Dec 16 2005, 07:29 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
a large drain pan is nice to have (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
TimT |
Dec 16 2005, 08:15 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
take the 0.004 blade out from your feeler gauge set and bend it, I bought some 004 feeler stock.. when the piece Im using gets to beat up, I cut and shape another piece of the shim stock |
J P Stein |
Dec 16 2005, 08:16 PM
Lo-Fi Version | Time is now: 24th June 2024 - 05:33 AM |
