Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
911 sender vs 914 sender
they ..... appear to have same exact threads as taco plate..... 914 is 6 - 24 v 911 is 6 - 24 v 914 is 200c max, 911 is 150c max.... here are some analysis pics (914 L 911 R) voltage range (IMG:http://www.914world.com/bbs2/uploads/blog-1134875825.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1134875864.jpg) temp range (IMG:http://www.914world.com/bbs2/uploads/blog-1134875832.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1134875840.jpg) physical size... (IMG:http://www.914world.com/bbs2/uploads/blog-1134875872.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1134875878.jpg) boiling water test next???? see the range on the gauge? |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
What's the next step ?
Looks like the 911 is going to need a special wire attachement; maybe a lead could be soldered to the end ? Let's test them both in boilng water while hooked up to the 904 gauge. If your not ready to test, I can do both, and on both the 914 and VDO gauges |
Aaron Cox |
well...the 911 one will work. id like to test the 914 one side by side with the 911 one... see if a resitor could be used... or maybe i should just spend the 30 bucks on a new sender LOL |
Aaron Cox |
btw - the 911 sender has like a "glow-plug" connector like an rc plane motor.... where as the 914 one has a spade.... (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
jim_hoyland |
Perhaps someone else has been down this path already....
Aaron Cox |
but alas...they are remaining quiet... i think bleyseng and MXMARK both have 911 temp/pressure gauges in their cars.... they must have used the 911 sender.... with a funky connector..,,, all is well jim. you are clear for takeoff (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
jim_hoyland |
VROOOOOOOOOOOOOOOOOOOMM...
Aaron Cox |
we have liftoff... in 3...2....1.... when am i gonna see ya next? or should i just mail it? or drive it down to joes? just for ease of testing- want to do the boiling water test to compare? |
ein 6er |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None ![]() |
the spade connector should slide right onto the round connector on the 911 sender, (if the diameter is the same as the width of the spade of course), i have the spade type connector on my 911 sender. |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Mine has the standard spade connector IIRC
Bleyseng |
There are two 911 senders.....
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 01:02 AM |
