bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay, so I know that L-jet uses the point pulses to fire injectors...my main relay is working, so what connections do i need at the coil?
i already have the tach wire, the point wire at the neg and nothing at the positive.... but i have a brown wire and two black wires joined to one both sets of wires having 12VDC on them....what gives? b |
bd1308 |
and i also have a white FI wire coming way off and out of the way of the harness which could also be the trigger wire....
why int he hell is a brown wire getting 12V? b |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,579 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Britt-
There is a series of 3 L-Jet diagrams under links on my wiring harness website for an L-Jet harness. Seet eh FI harness section. There are actually three different L-Jet 914 harnesses, so does this one match your harness? Maybe its of some help anyway. |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Your L-Jet is from a 1974.
The double relay has a black wire that goes to pin (15) on the coil. The ECU harness pin (1) goes to pin (1) on the coil {also supposed to be black} The 'other' wires terminating at the coil are: pin (1) Green to points pin (1) Black/Purple to Tachometer pin (15) Black (+12V from fuse S9) No brown wires should terminate at the coil. I believe you may have something wired incorrectly. Do you have the wiring diagrams? |
bd1308 |
let's do this step by step then:
A)where does the FI "WHITE" wire (that veers from the main bundle and is very long) terminate? Is it ground, or 12V? B ) There is a YELLOW wire over by the relay board...where does this item go? C) There is a set (two crimped together) of BLACK wires....where do these wires go? D) I see a tan wire, maybe even white coming from the relay board connector..12V on it. i tried a couple of combo's and all of them seemed to result in clicking from the dual relay... E) that lug from the dual relay (RED WIRE) is indeed 12V correct? b |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
The white wire may go to the AAR. It's just switched +12. The yellow wire is usually the starter wire, esp. if it's heavier gauge than many of the other wires.
bd1308 |
the yellow wire is regular sized wire...this harness is SO much different than my D-jet harness...
b |
JeffBowlsby |
L-Jet harnesses are completely different than D-Jet.
Draw us a diagram of your harness. Show how many poles each connector has and their location. Label each branch connector with a letter or number. Scan it and post it or email it to me. bowlsby@sbcglobal.net |
bd1308 |
mine is the 74 without the altitude compensator.
if you're referring to the OTHer harness coming from the relay board then I can do that for ya tomorrow. I'll take pics as well. b |
John |
(E) Red from the Dual relay -> To Batttery +12V
((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Yellow from Dual relay -> To Pin II of the (4) pin connector on the Regulator board (ties into starter yellow wire) (A) The white FI wires are numbered if you look closely (I believe in red) If you could get a number, I could tell where it goes. PM me your e-mail and I'll send you the AFC wiring diagram I just scanned for you. |
bd1308 |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
and the FI wire is labeled "1" which goes to the coil, presumably the negative terminal. b |
bd1308 |
oh and Jeff thanks for the figures on your site, I looked them up early yesterday.
I really appreciate it.... b |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
Gonna be 78 degrees F. here today Britt. Tom arrives here in about an hour. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) 'Detroit style' Coney Island chili dogs for lunch, chased down with Michigan apple cider. (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) John P.S. End of (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) |
bd1308 |
(IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) it's going to be 40F here, i'm stuck in the garage and my mom asks me every ten minutes if im done so she can put her jaguar back in the garage.
dang....sounds fun. I like apple cider. b |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Britt,
What do you need. We have a 74 ljet all done.... Let me know where you are at and I can go look at the live system. Rich |
bd1308 |
i am like almost there.....
im SO close.... I think that yellow wire is my culprit. Which pin is pin II? im trying to get the spark going...worked fine for months until today. and then i think once thats taken care of, the car will start right up. b |
r_towle |
Britt,
neg coil green wire to points white wire to FI harness, it comes out near the battery BL/BR wire Pos Coil dual black. Rich |
bd1308 |
yeah but that wierd white or brown wire (from dual relay) has 12V on it...
b |
r_towle |
I have the big dual relay thing, and the smaller dual square box style relay mounted to the battery tray...
Which wire are you talkng about... I will go look. Rich |
r_towle |
tell me , when you lay the harness down where it is supposed to go, where is this wire coming out of the harness?
I will go look there and trace the wire... Rich |
Lo-Fi Version | Time is now: 29th June 2024 - 02:23 AM |
