d7n7master |
Gary# ![]() ![]() ![]() Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 ![]() |
Hi All,
I'm in the process of re-installing my engine in my '73. Many of the nuts & bolts I removed to drop the engine have seen better days. Is there a hardware "kit" that I can buy that replaces all of the bolts, nuts, & washers I need to re-install the engine??? I especially need the bolts that attach the motor mount brkts to the engine & the bolts & nuts that attach the engine mount. Thanks, Here's a pic of my rebuilt 2165 "almost" is ready to install. Attached image(s) ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,359 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Seems you've been kinda left hangin'...
No I don't know of a kit of nuts and bolts, but I bet if you were to list the ones you need in the classifieds people have them. You could also take them down to a commerical type supplier they could match them up with new ones. Home Depot and Lowes always seem to be out of the right size metric ones when I need them. Check in your yellow pages. I have also heard the a Catapiller tractor dealer has every size in metric. You could also go the mail order route. McMaster/Carr or Granger will have them for sure, Paul |
MecGen |
8 Easy Steps ![]() ![]() ![]() Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 ![]() |
Hi
I don't thing that there is a kit but AA used to sell a bag of assorted used bolts.. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Cat does use a lot of metric bolts but you will be paying for the box... Happy hunting (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
I believe that nuts, in general, are all the same grade and are available in various finishes if that matters. On the other hand, the bolts DO come in many grades according to the job they are expected to do. The grade is marked on the head, and replacements should always be the same grade. The big trick is to know where each bolt came from.
Tom Perso |
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 ![]() |
I think Jake Raby's store has a whole hardware kit you can buy.
http://www.aircooledtechnology.com/store/p...&cat=300&page=2 Tom |
lincoln |
Member ![]() ![]() Group: Members Posts: 174 Joined: 9-December 05 From: Killeen Texas Member No.: 5,253 Region Association: None ![]() |
actually , since im up cuz some idiot was callin at 3 am , nuts also come in diff grades- for the laoder / dump type trucks we build at work tho we only use grades 8 and 5 8s on major stress areas like frame and rest usually the grade 5s
URY914 |
I was thinkin' that if anyone would have a kit pulled together it would be Jake, but I did't know for sure and didn't check. Now I know. Paul (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
That hardware kit has every nut, bolt and washer to build a T IV longblock... We count every piece.
Lo-Fi Version | Time is now: 29th June 2024 - 01:46 AM |
