Poor-sche Lover |
Member ![]() ![]() Group: Members Posts: 67 Joined: 25-November 05 From: SE Kansas Member No.: 5,190 ![]() |
Howdy all,
I'm looking for a good way of cleaning the pistons and heads I just pulled off my engine. Apparently, it had been running VERRRRRRRRY rich, with some bad piston rings, because there is all kinds of crap and corruption in there. Some of it looks like carbon deposits and caked oil, but some seems to be just discoloration, like there's no depth to the crap; it's just a stain. I have already used Gunk degreaser, soaking in Seafoam, and Easy-Off. It helped a lot, but there is still a ton of work to do. I started scraping with a feeler gauge, but I'm worried about scratching the pistons, valves, heads, etc. Any suggestions? I'm more concerned with the crunchy stuff rather than the discoloration. I'll get some pictures if you think it'll help. Thanks. |
Dead Air |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 ![]() |
grab some carb cleaner (not aerosol) and sooooooooak it.
root |
Two Wheeled Type4 Completed! ![]() ![]() ![]() Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Also, if you bubble some air into the soak tank at low presure/flow the whole soak process is accelerated greatly! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) Be sure to ventilate the room well or (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Blair and I have broken down the 2 1.7 motors I had laying around. One has some good domed 90mm pistons that we will reuse. The other had been rebuilt recently so that one will be installed (with the domed pistons) in the 72 Black car to get it running. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:54 PM |
