pedrini refinish options?, any suggestions? |
davesprinkle |
Feb 7 2006, 01:04 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I've got a set of very weathered Pedrinis on my 14. Setting aside, for now, the obvious way to improve their appearance (5-lug conversion, duh), can I get any suggestions on refinishing?
Powdercoat -- cheap (~$75/wheel), durable, attractive, but there is some speculation that the baking process might affect the strength of the alloy Paint -- probably the best way to duplicate the factory finish, but surprisingly expensive (~$150/wheel), and of dubious durability Polish -- don't know about expense (maybe the same as powdercoat?), looks good initially, but requires continual attention Thoughts, vendors, other options? Thanks in advance. |
smg914 |
Feb 7 2006, 01:15 PM
Sahara Beige Steve Group: Members Posts: 1,970 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Bead Blast them and then shoot them with Wurth Spray Lacquer Silver
Gint |
Feb 7 2006, 01:23 PM
Mike Ginter Group: Admin Posts: 16,095 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Al and Diane can do pretty much whatever you want. Or certainly everything on your list. Give 'em a call.
Al Reed Specialty Polishing 3010 E. Coronado #A Anaheim CA. 92806 714-632-3907 |
double-a |
Feb 7 2006, 02:46 PM
Senior Member Group: Members Posts: 989 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i decided to sandblast and polish my set of mahles. they look great, but i do not recommend it, have someone else do it. even with a dremel contour sander it takes 8-10 hours per wheel. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
~a |
Bill Shaw |
Feb 7 2006, 04:22 PM
Member Group: Members Posts: 74 Joined: 11-August 03 From: Kalamazoo, MI Member No.: 1,013 |
Refinished my Mahles in the garage with the paint kit from Griot's Garage and it turned out perfectly, though I'm certainly not a genius with a spray can. Has held up for 2 years in Michigan and still looks good. Just scuffed them with 400 grit, blew the dust off and started painting.
BarberDave |
Feb 7 2006, 05:41 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dave:I powder coated my Mahles last yr. I really like it ,cleans with soap and water back to like new every time. Don"t have to worry about stone chips. Gets my vote. Dave (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) |
Mueller |
Feb 7 2006, 05:59 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
if you plan on converting to 5-lug down the road, I'd do a cheap, easy refinish of the wheels since it'll be difficult to recoup the money spent if you do a finish or color that others might not like.........silver paint or your favorite color seems to be the best method...it's easy to remove once you sell the rims if the new owner wishes to re-do the finish....
carreraguy |
Feb 7 2006, 09:59 PM
It's not your dad's 914! Group: Members Posts: 1,197 Joined: 17-October 03 From: San Jose, CA Member No.: 1,256 Region Association: Northern California |
If you have some $$$ and are not in a big hurry, you can't go wrong with Weidman's Wheels. George Weidman is a real perfectionist and does great work.
1675 Wyandotte Ave Oroville, CA 95966 (530) 534-7903 |
p914 |
Feb 7 2006, 10:46 PM
Senior Member Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None |
media blast with plastic. The matte finish is really nice by itself. Around $25 per wheel.
johnmhudson111 |
Feb 26 2006, 05:02 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Thanks, I passed along Al's info to my dad. |
Aaron Cox |
Feb 26 2006, 05:06 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
if your just going to sell em when you go 5 lug, beadblast, paint, and the clear.....
painting a wheel is 150 bucks?uh... maybe if you do 10 wheels....... 15 each maybe.... |
davesprinkle |
Feb 26 2006, 05:40 PM
Maybe I should have clarified that the $150 quote was given to me by Wheel Enhancement. I understand that a DIY approach would be significantly less expensive. But since you mentioned bead-blasting, what vendor do you use for your bead-blasting? |
Rand |
Feb 26 2006, 05:49 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I have heard that aluminum can become brittle if heated to 410 degrees. I don't know about other alloys, but FWIW, I do know there are some low-temp powder coats that don't have to get nearly that hot.
Aaron Cox |
Feb 26 2006, 06:07 PM
i know this guy..... who has one (thanks slits) |
biggy72 |
Feb 26 2006, 09:14 PM
Member Group: Members Posts: 209 Joined: 14-January 06 From: Olympia, WA Member No.: 5,418 Region Association: Pacific Northwest |
I sent mine to Al Reed. It was awhile back, but I think he charged something like 75 a piece? Not sure, but they turned out amazing.
Attached image(s) |
Lo-Fi Version | Time is now: 4th January 2025 - 06:12 PM |
