d914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States ![]() |
Can't find the thread!!! (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
connect the two big yellows together, eliminate the others???? Was this right????? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Under the seat, there is a heavy yellow wire, and a heavy yellow wire with a red stripe on it. Splice the 2 wires together. The rest are not necessary for the operation of the car. But you can hook up the brown wires and get the dome light to work correctly.
d914 |
thanks
ClayPerrine |
Be careful.. there is one wire, a thin black one, that runs to the fuse block. It comes from the ignition fuse. If it grounds out, it will kill the ignition.
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
There goes your seat heaters... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
d914 |
yup,,,,,, (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Lo-Fi Version | Time is now: 29th June 2024 - 01:36 AM |
