deserttoad |
Newbie ![]() Group: Members Posts: 35 Joined: 24-January 06 From: Lovelock, NV Member No.: 5,468 ![]() |
I've just recently gotten this car running, and things seem pretty good. It smokes a bit, but then again it hasn't been licensed since 1988. I've replaced all the vacuum lines and I've also replaced all the ignition parts (coil, points, rotor, condeser, cap, wires, and plugs).
So my question to you all is what else would you check or do? Remove any of the smog stuff, perhaps replace that egr valve? Also I have some terrible exhaust leaks - would this cause any problems with the running of the motor? It's not registered yet so the noise doesn't bother. One more question - the nipple is busted off the charcoal canister, I know I don't really need it anyway, but with the open hole be a prob? Also - here in this town, there are no smog checks on vehicles. thanks, DT |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If no smog, loose all the smog stuff.
I have never seen one with smog stuff, but I hear the heat exchangers are restrictive and create more heat in the engine...so get rid of those, get earlier ones... Get rid of the EGR system all together. So, get new/used SS heat exchangers... get rid if the charcoal canister Get in a drive it till it dies. Rich |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Go through the brakes before you actually start zooming down the road.
Lo-Fi Version | Time is now: 28th June 2024 - 07:49 PM |
