transponder in race car, best place to mount |
Albert914 |
Mar 1 2006, 10:38 AM
Newbie Group: Members Posts: 5 Joined: 23-April 05 From: San Jose, Ca Member No.: 3,968 |
I have a driving school to attend this weekend and they require a transpounder on all cars. where is the best place to mount this on a 914? I don't want it to get damaged by flying objects.
nine14cats |
Mar 1 2006, 10:42 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I have an AMB clip and I mount it on the rear f/g bumper of our 914. It seems to be protected.
Bill P. |
Marv's3.6six |
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
Don't know about transponders.. but I mounted my hot lap sensor on the dash, looking out the passenger side of the wind screen.
URY914 |
Mar 1 2006, 10:45 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,247 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I put mine inside the front fender just behind the turn signal.
seanery |
Mar 1 2006, 10:46 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
in the front! First across the line wins, right! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Is it an AMB? If so, they are easy to mount. In the front wheel well or behind the front bumper. There should be no obstruction between the transponder and the loop. From the Florida Region of the SCCA
seanery |
Mar 1 2006, 10:48 AM
Paul, you don't have turnsignals anymore do you? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
jhadler |
Mar 1 2006, 11:17 AM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Is it -your- transponder? Or are you renting it? If it's a rental, just screw the mounting clip into the front license plate mount. The transponder will point down and will be unobstructed. These AMB transponders are -tough- critters. It practically doesn't matter where you mount them as long as it's less than 24" off the ground, is pointing down, and there is no metal between the transponder and the ground.
I've seen front mounted transponders come out unscathed when cars go into tire walls. These suckers are -tough-. It takes quite a bit to bend 'em, even more to break 'em. Just make sure it's well mounted to the car. It's a lot easier to -loose- one than it is to break one. -Josh2 |
VegasRacer |
Mar 3 2006, 08:03 PM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
You're gonna have to look in my blog to find out where I mounted mine last week. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
brant |
Mar 3 2006, 08:09 PM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I agree with the front area...
Bill, why have it in the rear? If someone is beside you the computer will show them as crossing the finish line first. I've mounted AMB's in 2 914 race cars. there is a sweet spot inside the passenger wheel well, on the inner fender, behind or inside of the strut. it is a clear shot down to the loop. and nearly goes through the lower a-arm. very very protected from debree, and even crash damage. its only about 8 inches behind the front bumper but much more structurally sound and also shorter wires/easier to wire. I'll look for a pic. brant |
drew365 |
Mar 3 2006, 08:13 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
Mine is mounted on the front bumper but is illegal. POC rules call for it to be no more than 6" forward of the front axle. I'm probably going to move it to the rear bumper since inside the wheel well is hard to get at and it seems like it would get beat up there.
Attached image(s) |
campbellcj |
Mar 4 2006, 12:39 AM
I can't Re Member Group: Members Posts: 4,593 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Mine is hardwired behind the front bumper and wired via the factory foglight circuit...has worked great so far. Andy I guess I hadn't noticed that 6" rule...crap. Maybe in the front trunk pointing down thru the oil cooler exhaust cutout would work?
ChrisFoley |
Mar 4 2006, 08:06 AM
I am Tangerine Racing Group: Members Posts: 7,968 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Mine's in the passenger side wheel well, ahead of the axle line. It's in an area that is well protected, is low, easy to access and has a straight shot down to the ground.
drew365 |
Mar 4 2006, 08:07 PM
I haven't seen it in the GCR's myself, but Bob Taylor keeps telling me that's the rule and if I beat someone in my class they can protest because of the transponder being illegal. I just tell him there's a fat chance I'm going to win V3/ R5, but I plan on moving it. |
Lo-Fi Version | Time is now: 26th December 2024 - 10:27 AM |
