914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None ![]() |
Posted on the bird, got some info, but still not quite sure.
Do I need to remove the 10mm nut in the center of this picture, and adjust on the splines? If so, don't I need to remove the other end, too? (IMG:http://img.photobucket.com/albums/v520/bak535/headlightadjust.jpg) |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
What are you trying to accomplish.
There is a screw and lock nut behind and sotra under the back of the light housing. This adjusts how much the light can pivot. Caution you can really screw this up. Once you got it going to far in one direction then at least you know how to get back. IS it not closing all the way? are all the little bushings in good shape. that will throw it off with no hope of getting it right. |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Andy? Are you back east? (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) sorry... KT |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
do a search here, we just had a thread with very detailed instructions about this 2 or 3 weeks ago ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
SirAndy |
found it for 'ya ...
http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=45959 (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy |
914-8 |
Thanks!
My problem is when the headlights go down, they go down a bit too far. Making it hard to get all the alignments (headlight, hood, blind, etc.) just right. |
SirAndy |
yes, i know ... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) and if you read the post which i gave you a link to, it will aswer your question on how to adjust the headlight correctly so it won't go down too far ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 04:40 AM |
