sportomatic, Gear ratios |
bernbomb914 |
Mar 29 2006, 04:48 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
Took the Sport-o-matic trans out of a 77 911 apart and the gear ratios are
C 1st HB 2nd R 3rd Y 4th Just in case you wanted to know. They look brand new because of the automatic clutch. I think I will use the HB in my trans flipped is there another ratio that would help also? Bernie (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Aaron Cox |
Mar 30 2006, 01:16 AM
bernie, id like the C if its cheap enuff...
been hunting for a 905 sporto for a while |
alpha434 |
Mar 30 2006, 01:19 AM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Was it a 905? I would like the automatic clutch assembly to fiddle with... and maybe the case.
bernbomb914 |
Mar 30 2006, 09:29 AM
I did not get the clutch assy or bell housing but I have the case.
Aaron is the C gear set a longer 1st? I was told it came from 77 911 is that a 905? |
bondo |
Mar 30 2006, 10:20 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
What's the R&P ratio?
Aaron Cox |
Mar 30 2006, 01:06 PM
if its from a 77, i want to say that its a 925......... (915 based (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) )
but yes. a C is a reallllly tall first - lemme know if you want to part with it |
bernbomb914 |
Mar 30 2006, 06:02 PM
the ring and pinion is 7/27 ratio
Bernie |
Lo-Fi Version | Time is now: 24th June 2024 - 07:32 AM |
