Warning lights on left gauge, What are they? |
LowGT |
Apr 1 2006, 10:46 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
Ok, this is kind of a simple question but I haven't been able to find the info anywhere.
On the far left gauge with the fuel level on the bottom, what are the warning lights for in that gauge? There is a small red light and then the black screen across the top. I just finished putting the engine back together and when I went to start it I got the little red light until the car started. Thats normal. Then the left half of the black screen started blinking orange. I don't know what its for, hell I didn't even know it still worked. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
cbenitah |
Apr 1 2006, 10:49 PM
Protected by the Swedish Maffia Group: Members Posts: 848 Joined: 16-August 05 From: San Diego, CA Member No.: 4,597 |
hand break... at least on my car (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
type47fan |
Apr 1 2006, 10:51 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Small red light is the alternator warning light (goes out when the alternator is charging) and the large flashing light is the brake warning light. Tells you that your parking brake is engaged. . . .
How's the little green light (oil pressure) on the right side of the gauge? |
LowGT |
Apr 1 2006, 11:29 PM
Handbrake, that's it. Now it makes since it turned off when I started driving, cause I released the handbrake. I wonder why it started working all of a sudden. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
The oil light has never come on, I don't know if it even works. What about the other half of the handbrake warning light? Is that for something else, or is the whole thing supposed to light up for the handbrake? |
cbenitah |
Apr 1 2006, 11:34 PM
the whole thing lights up bright and shiny |
shaggy |
Apr 1 2006, 11:37 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
the entire top is hand brake its divided into 2 sections both should light (both red)
left middle is alternator (red) right middle is oil pressure (green) (idiot light) in the bottom left of the fuel gauge is the low light(orange) im not sure exactly what it symbolizes (1/4 tank, 1/8 tank?) i just know that every time i corner and see it flicker i fill up hope that helps -shag |
Joe Bob |
Apr 1 2006, 11:41 PM
There's a switch in the handbrake.....sometimes they get gunky from not being used.....use it and it gets ungunked..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
gothspeed |
Jul 22 2009, 03:01 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Handbrake, that's it. Now it makes since it turned off when I started driving, cause I released the handbrake. I wonder why it started working all of a sudden. <!-- emo&:confused: -->(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)<!-- endemo --> The oil light has never come on, I don't know if it even works. What about the other half of the handbrake warning light? Is that for something else, or is the whole thing supposed to light up for the handbrake? Mine just started working all of a sudden too (IMG:style_emoticons/default/confused24.gif) ........ though I wanted to ask anyone who might know where the 'trigger' switch is for the parking brake light? Also my left turn signal does not flash the lights ...... but when I accidentally leave the post in LH position, the lights stay on after I switch the ignition off ...... (IMG:style_emoticons/default/unsure.gif) ....... any help with either of these questions is very appreciated (IMG:style_emoticons/default/smile.gif)!!! |
underthetire |
Jul 22 2009, 03:08 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Mine didn't work either until I asked about it here. Little door type plunger switch under the handle. I sprayed a little WD40 type lube around it. Works every time. The turn signal thing with the key off is normal. Asked about that here to.
neil30076 |
Jul 22 2009, 03:16 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
QUOTE Also my left turn signal does not flash the lights ...... but when I accidentally leave the post in LH position, the lights stay on after I switch the ignition off ...... (IMG:style_emoticons/default/unsure.gif) ....... any help with either of these questions is very appreciated (IMG:style_emoticons/default/smile.gif)!!! The left hand lights will stay on if you run the ignition off with the left directionals flashing, I believe the right does the same - its a parking light at night! My 928 and both Land Rovers do this also - its a European 'thing' (IMG:style_emoticons/default/smile.gif) |
7TPorsh |
Jul 22 2009, 03:29 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I was just going to post a question like this! Thanks for the answer...but, my top crescent shaped light is split in two. Left is the hand brake and the other acts like an alternator light(red)...I don;t see my green one go on at all.
gothspeed |
Jul 22 2009, 04:40 PM
Mine didn't work either until I asked about it here. Little door type plunger switch under the handle. I sprayed a little WD40 type lube around it. Works every time. The turn signal thing with the key off is normal. Asked about that here to. QUOTE Also my left turn signal does not flash the lights ...... but when I accidentally leave the post in LH position, the lights stay on after I switch the ignition off ...... (IMG:style_emoticons/default/unsure.gif) ....... any help with either of these questions is very appreciated (IMG:style_emoticons/default/smile.gif)!!! The left hand lights will stay on if you run the ignition off with the left directionals flashing, I believe the right does the same - its a parking light at night! My 928 and both Land Rovers do this also - its a European 'thing' (IMG:style_emoticons/default/smile.gif) Yes the ignition off 'staying on' part is normal ....... but the LH signal lights do not light or flash at all with the ignition on during normal driving ..... (IMG:style_emoticons/default/sad.gif) |
underthetire |
Jul 22 2009, 04:50 PM
I was just going to post a question like this! Thanks for the answer...but, my top crescent shaped light is split in two. Left is the hand brake and the other acts like an alternator light(red)...I don;t see my green one go on at all. Green one should come on with key on/engine off. Did someone put a oil pressure gauge in ? Maybe the bulb for the oil pressure lamp was switched with the brake lamp by mistake? Burnt out bulb? |
7TPorsh |
Jul 22 2009, 05:40 PM
so what should be what?
on my car; 1; handbrake 2: on with key and engine off; turns off when i start car (alternator?) 3:doesn't light 4: doesn't light |
underthetire |
Jul 22 2009, 05:44 PM
so what should be what? on my car; 1; handbrake 2: on with key and engine off; turns off when i start car (alternator?) 3:doesn't light 4: doesn't light 1&2 should be the same. Parking brake/low brake pressure warning 3 generator (charging) lamp. Should come on with the engine not running. 4. oil pressure warning. Should come ON with low/no oil pressure |
partsman |
Jul 22 2009, 05:47 PM
forever hooked Group: Members Posts: 276 Joined: 27-February 04 From: Bradford, MA Member No.: 1,726 Region Association: North East States |
3 is alternator
4 is oil pressure I always thought 1 and 2 were one bulb?? that lit the whole warning light...if they're split I would imagine that one would be a warning for parking brake left one, and the other would be a low brake pressure warning.. Eric |
ellisor3 |
Jul 22 2009, 07:59 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
Not to hijack the thread, but my red light just started staying on when the switch is off, and the key is out. (IMG:style_emoticons/default/WTF.gif) I had to disconnect the battery cable to keep from running the battery down.
Attached image(s) |
Dave_Darling |
Jul 22 2009, 10:57 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The diodes in the alternator are bad. Time to replace the alt.
--DD |
gothspeed |
Jul 23 2009, 12:50 PM
Yes the ignition off 'staying on' part is normal ....... but the LH signal lights do not light or flash at all with the ignition on during normal driving ..... (IMG:style_emoticons/default/sad.gif) Can anyone shed light on this problem on my 'quoted' post (IMG:style_emoticons/default/confused24.gif)? |
gothspeed |
Jul 23 2009, 03:38 PM
BUMP ^^^^^
Lo-Fi Version | Time is now: 30th June 2024 - 08:43 PM |
