> cooling fan removal
G e o r g e
post Apr 3 2006, 08:39 PM
Dr
before i drive to germany, are the 3 bolts that hold the cooling fan on 12 point 5mm? or 4mm? or were these supposed to be a differant bolt all together? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
George
bd1308
post Apr 3 2006, 08:46 PM
Sir Post-a-lot
different bolt...
if you dont know, try the 13mm socket. <
its 13mm.
b
mcbain77
post Apr 3 2006, 08:58 PM
I used the 12 point (triple square) M8 size bit to remove mine. PITA. I stripped one and had to use a bolt remover to get it out. I need a replacement bolt come to think of it.
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
G e o r g e
post Apr 3 2006, 09:10 PM
Dr
never mind, put some better light (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) and found that the 8 mm 12 point was the tool.
George
bd1308
post Apr 3 2006, 09:12 PM
Sir Post-a-lot
wierd....
on my 2 engines, they have the 13mm bolt.
b
mightyohm
post Apr 3 2006, 09:15 PM
Britt,
There are two styles of fan. One uses the bolts and the other uses the triple square.
- Lo-Fi Version Time is now: 4th January 2025 - 06:34 PM
