Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Anybody in the Sonoma, Napa, Marin area that has this tire/wheel combo that would help a brother out? I want to check for fittament before I convert to 5 bolt. I want to put 1 lug nut in, undo my shock and check clearance.
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
6" or 7" and what offset??
a 6" will fit perfect, a 7" might need just a "little" rear fender tugging or lip rolling |
Krieger |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I'm coming from the land of 2 Litre alloysI thought that they were the same. All 6x16, all 7x16. How can I find out?
Mueller |
16x7 Phonedials on all 4 corners (23mm offset which is the common 16x7 Fuchs offset as well) with 205/50's
great fit up front, on the rear I had to roll the fender lip and tug on the fender near the back half to prevent tire rub. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:23 PM |
