3 Pages V  1 2 3 >
> Exploring the "Hell Hole"
Neal
post Sep 17 2003, 02:01 PM
How does one inspect the hell hole looks like you can't see much from up on top.
Geoff looked at mine quickley but I would like to dig a little deeper. Any suggestions
Neal
post Sep 17 2003, 02:15 PM
Resident German
take the battery and brain out and get some good light in there.
then, use a big screw driver and try to poke holes in your frame rail.
pray that it won't work ...
Andy
J P Stein
post Sep 17 2003, 02:51 PM
Irrelevant old fart
I stick my hand down in there.....and have the scars to prove it. If you feel holes, fergit it....no holes makes it worth a closer look... along Andy's lines.
I've "felt up" a bunch of 914s. Does that make me some kinda pervert? (IMG:style_emoticons/default/laugh.gif)
reverie
post Sep 17 2003, 04:30 PM
I need to do that, too.. have a good look from above and underneath, remove the rocker covers, look around. I see some rust, and I want to see how serious it is so I can prioritize my spending. (IMG:style_emoticons/default/wink.gif)
post Sep 17 2003, 04:41 PM
Resident German
also, more often than not, it is rusted through the side wall.
jack the pass. rear up, take the wheel off, get a good light in there
and check for rust on the inside fender well.
i did patch the holes from both sides, kinda like a sandwitch.
should last for a while.
Andy
framerail from above:
(IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0262.jpg)
same, plus fender hole patched:
(IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0267.jpg)
from inside the fender:
(IMG:http://www.sirandy.com/pix/914/07.30.2002/IMGP0268.jpg)
post Sep 17 2003, 04:44 PM
Resident German
and the final result, just ingore the sand, this pic was taken AFTER the beach party (IMG:style_emoticons/default/wink.gif)
(IMG:http://www.sirandy.com/pix/914/2003.04.14/IMGP1701.jpg)
Bleyseng
post Sep 17 2003, 05:32 PM
Aircooled Baby!
A shot of my hell hole all purdy....
Neal
post Sep 17 2003, 06:20 PM
I ventured into the Hell Hole and found it only the purgatory hole the attached photo is the small hole I found, I assume I have to remove the battery tray and patch the hole ?, or are treated little holes ok to live with ?.
Neal
post Sep 17 2003, 06:22 PM
P.S all the metal except the hole is sound, I poke with a big ass scredriver and only found this one spot.
post Sep 17 2003, 06:36 PM
Resident German
patch it. you don't want anymore stuff falling (and rotting) in your framerail.
cut out the cancer. don't leave any behind. get some "metal-ready" and spray it inside the frame rail, trough the hole. then weld shut.
Andy
Hawktel
post Sep 17 2003, 06:44 PM
I think the issue is what does the behind that hole look like?
It could be a time bomb.
(IMG:style_emoticons/default/sad.gif)
post Sep 17 2003, 06:46 PM
Resident German
QUOTE(Hawktel @ Sep 17 2003, 05:44 PM)
yepp, that's why you should cut it out. have a look inside.
if it's only surface rust, put plenty of metal ready in there and weld it shut.
otherwise, start cutting out rust from the underside ...
Andy
DNHunt
post Sep 17 2003, 08:28 PM
914 Wizard? No way. I got too much to learn.
Sounds like a few of us up here in the Emerald City are going to be cuting and welding. I just got a couple pieces from Restoration Designs but the pieces I really need are not available. Apparently, they need to make some new dies and it may be a while before they do. I'm hoping the lower firewall and inner fender are not too bad and can be patched rather than replaced.
I should find out pretty soon. I'll have it up on blocks in a month.
Dave
scotty
post Sep 17 2003, 09:34 PM
The Fun Never Stops
I've "felt up" a bunch of 914s. Does that make some kinda pervert?
...only if you didn't enjoy it! (IMG:style_emoticons/default/laugh.gif)
Get an Optima battery and or move the battery for total peace of mind after you fix it.
Neal
post Sep 17 2003, 09:46 PM
Please give me a tutorial on "cut it out" and what needs to be removed to accomplish this. Do I have to remove the battery tray or can it be done with the try in place, also should I inspect from the wheelwell ?. This is my daily driver so this will be a slam bam fix for sure.
Neal
post Sep 17 2003, 10:05 PM
Resident German
QUOTE(Neal @ Sep 17 2003, 08:46 PM)
Neal
depending on where exactly that hole is the tray might be able to stay in there.
if you can't get in and do the work because the tray is in the way, and the tray itself is not rusted, drill out the spot-welds so you can weld it back in afterwards.
cut out the rusty area with a cutoff wheel, give yourself plenty of room, meaning cut PAST the rusted area. cut a square (rectangle) hole so you can patch it easy with some sheet-metal. make the sheetmetal bigger than the cut-out, like at least 1/2" wider all around. drill holes in the new sheet metal and weld like you would do spot welds. when done, you can lay a seam around the piece if you want. if the area is not flat, make sure the patch sheet is molded into whatever shape you need. this is done with cuts and a BFH (IMG:style_emoticons/default/smash.gif)
if you look closely, you can see that in my first and second pic.
Andy
reverie
post Sep 17 2003, 10:11 PM
Neal, it might be cost-effective to ask a local shop to do the patch or whatever. I'm not sure if Redmond European does this kind of thing.. there's a better chance that Mercer Island Svc Cntr would do it, and very reasonably too. Their hours are usually 7:45 - 4:00, M - F .. bring in the pic, and ask for Carl or Richard.. they have LOTS of Porsche experience.
Dave, you might try Stoddard's..?
Bleyseng
post Sep 18 2003, 07:53 AM
Aircooled Baby!
It would be better to trash the tray and support so you can get in to do the work.
I laid the new metal in and butt seam welded it so it you couldn't tell it was put in unlike Andy's. The rusty stuff must cut out regardless and good new metal installed to protect the long.
The new support and tray get welded in last.
Geoff
tracks914
post Sep 18 2003, 08:10 AM
Canadian Member
Here is a picture of what I had to cut out. With the battery tray out I found more rust. The picture doesn't show all that I cut out before I repaired it all but it gives you an idea of the work involved in trying to do the repair with the tray in place. (IMG:style_emoticons/default/blink.gif)
Trays are cheap and yours probably needs replacement if it never has been yet.
tracks914
post Sep 18 2003, 08:12 AM
Canadian Member
And after the repair.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 26th December 2024 - 12:23 PM
