flyloki |
Member ![]() ![]() Group: Members Posts: 138 Joined: 20-October 03 From: 8:00 in Boise, Idaho Member No.: 1,264 ![]() |
Could a Type 1 VW motor bolt right up to a 901 with no adapter?
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
flyloki |
Any reason for the diff flywheel? Application is an electric motor adapter plate that is designed for type 1 trannys. |
Aaron Cox |
i know the 4 bolts from case to tanny are in the same points.....
whats the OD of a vw flywheel? 914? not sure what is required on the clutch side of things |
Lo-Fi Version | Time is now: 26th June 2024 - 02:42 AM |
