How many bolts hold on the plenium? |
tod914 |
Jun 2 2006, 11:56 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
75 2.0... only seen one towards the front.. I assume there are more??
Thanks |
Rand |
Jun 2 2006, 12:03 PM
Yup, and one at the back too. The same one that stumped me. (IMG:style_emoticons/default/wink.gif)
Dave_Darling |
Jun 2 2006, 04:41 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe it's three. Two toward the front, that bolt up to a couple of the engine tin screws. (One toward the left-front, one toward the right-front.) Plus the one at the back, that uses one of the crankcase through-bolts to hold it in place.
--DD |
tod914 |
Jun 2 2006, 04:58 PM
Great thanks guys... any kind of seal or anything ill need when it goes back on?
Allan |
Jun 2 2006, 05:08 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Here's a pic that "MAY" help. It is 3 bolts like Dave said. If you pull the throttle body off of the plenumn you'll need a new gasket and they are nla BUT, I took my throttle body to the local vw parts house here in town and they were able to fit it with one off of a t-1 that only required a little cutting.
Attached image(s) |
So.Cal.914 |
Jun 2 2006, 05:11 PM
Gadd's, Dave the human 914 encyclopedia.
jd66921 |
Jun 2 2006, 06:02 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Okay Dave (or whoever), is it easy enough to remove the whole plenum since it is
almost impossible to install the throttle body to the plenum? This is a 1.8 L-Jet. How many bolts are there? Thanks, Jeff |
tod914 |
Jun 2 2006, 06:09 PM
Thanks Allan for taking the time for the photo. Answers my question (IMG:style_emoticons/default/smile.gif)
Dave_Darling |
Jun 2 2006, 06:44 PM
I haven't worked with a 1.8 plenum (I never messed with the one on my old 1.8). The one pictured above, and the one we've been talking about, is a 2.0 one.
I would guess (and it's only a guess!) that there are similar connections on a 1.8, but I don't really know. It might be easier to pull the plenum (though I have found I have to pull the intake runner pipes off the motor to remove the 2.0 plenum), but I don't even know how the 1.7/1.8 throttle body is held to the plenum at all. Damn long way of saying, "I dunno!" --DD |
Cap'n Krusty |
Jun 2 2006, 07:00 PM
The gasket for the TB is NOT NLA. There was a post today that mentioned picking one up at the dealer. The T1 gasket is much smaller, and the 1.7 and 1.8s use a rubber or plastic cone. Those are NLA, and have been for years. The Cap'n
tod914 |
Jun 2 2006, 08:31 PM
Cpt, would a 2.0 engine gasket kit contain a new TB gasket?
jd74914 |
Jun 2 2006, 08:39 PM
Its alive Group: Members Posts: 4,819 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Okay Dave (or whoever), is it easy enough to remove the whole plenum since it is almost impossible to install the throttle body to the plenum? This is a 1.8 L-Jet. How many bolts are there? Thanks, Jeff I actuallu put mine on and took it off again 3 times 2 weekends ago. Its very easy and IIRC there are 3 bolts to the case from the plenium. I found that it was much easier to pull off the plenium to put the TB and a few other things on, than leaving it on. (IMG:style_emoticons/default/smile.gif) |
Joe Bob |
Jun 2 2006, 09:35 PM
Unregistered |
Plenium???
I opened the thread to find what it was....geez, must be bored.... |
Allan |
Jun 3 2006, 06:22 AM
StratPlayer |
Dec 24 2006, 12:01 PM
StratPlayer Group: Members Posts: 3,300 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
The 2 bolts on the top of the plentium are they competely necessary for a proper install. I have the plentium mounted as a preassembly of the motor. The is no where on this case for the bolts to thread into, I have the other 3 connecting points connected. Just wondering about the 2 long bolts that fit into the top of the plentium.
Attached image(s) |
rmital |
Dec 24 2006, 03:26 PM
Northeast optimist Group: Members Posts: 1,953 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Tod...thought your car was in storage, what's up?
...or what are you up to... |
Lo-Fi Version | Time is now: 5th January 2025 - 12:23 AM |
