germaneighter |
Member ![]() ![]() Group: Members Posts: 130 Joined: 9-August 05 From: Tulsa, OK Member No.: 4,563 ![]() |
Does anyone have detailed instructions for doing an "at home" driveway alignment? (with pictures would be nice)
Rear Shims are no problem. I can get some laser cut in different thicknesses. (Local independent Porsche shop estimates $400 for a proper alignment.) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,410 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Crap I just did one on my car Monday evening.
From rear shims to Front camber caster front and rear toe. I get gun shy posting pics of my Red Neck procedures as it is surely not up to the standards some here are accustomed to. But the results are hardly questionable. goes straight turns in quickly and heats the tires evenly across the face. |
John Se |
Newbie ![]() Group: Members Posts: 29 Joined: 14-February 06 From: Scottsdale AZ Member No.: 5,579 ![]() |
You need the book "prepare to win" by caroll smith
just need some strings or long bars to create a parrallelogram (sic?) arount the car and measure it up |
germaneighter |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
I have an article on the Pelican site and it has conversions for fractions of an inch to degrees camber and toe in/out for 15 inch wheels included.
Joe Ricard |
Yup John's article rocks!!!!
http://www.pelicanparts.com/techarticles/h...home_toe_in.htm |
Rand |
Link? Guess I can go search later, but if you have it that would be nice.
KenH |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 ![]() |
Read these. You can make "strings" with conduit and attach to the car by the license plate screws. You can buy a caster/camber tool off ebay. You wil spend a lot less and have a set-up you can use again. Email me if you want more info.
Ken http://www.smartracingproducts.com/pdfdocs...mber_manual.pdf http://www.smartracingproducts.com/pdfdocs...ings_manual.pdf Oh - turnplates can be 2 sections of slippery masonite placed "face-to-face" |
germaneighter |
Is toe measured from the wheel or the tire?
It seems 1/8" total toe in at the front of the tire would be slightly less at the front of the rim. |
Joe Ricard |
RIM
Because John's figures are off of a 15" circle. I would try 1/16" toe in on each wheel for a total of 1/8" toe in. I did 1/32 toe out the other day and it's not quite enough as the car kinda wanders. More toe out will give me quicker turn in low speed cone dodging. |
KenH |
Porsche specifies Toe in "degrees". Measure from the rim. You will have to calculate degrees as it depends on the "measured" diameter of the rim.
Ken |
Joe Ricard |
Yup degrees is good BUT John makes it easier
Toe measurement 1/16 inch or 0.0625 inch = Toe angle 8.95251minutes Toe measurement 1/8 inch or 0.125 inch = Toe angle 17.9051 minutes Toe measurement 3/16 inch or 0.1875 inch = Toe angle 26.8578 minutes Toe measurement ¼ inch or 0.25 inch = Toe angle 35.8106 minutes Toe measurement 5/16 inch or 0.3125 inch = Toe angle 44.7638 minutes Toe measurement 3/8 inch or 0.375 inch = Toe angle 53.7172 minutes Toe measurement 7/16 inch or 0.4375 inch = Toe angle 1.04452 degrees Toe measurement ½ inch or 0.5 inch = Toe angle 1.19375 degrees Toe measurement 9/16 inch or 0.5625 inch = Toe angle 1.343 degrees Toe measurement 5/8 inch or 0.625 inch = Toe angle 1.49225 degrees Toe measurement 11/16 inch or 0.6875 inch = Toe angle 1.64152 degrees Toe measurement ¾ inch or 0.75 inch = Toe angle 1.79079 degrees Toe measurement 13/16 inch or 0.8125 inch = Toe angle 1.94008 degrees Toe measurement 7/8 inch or 0.875 inch = Toe angle 2.08938 degrees Toe measurement 15/16 inch or 0.9375 inch = Toe angle 2.23869 degrees Toe measurement 1 inch = Toe angle 2.38802 degrees |
germaneighter |
Can use a magnetic angle finder mounted directly to the strut body to set caster?
germaneighter |
I meant that as a question....Can I use a magnetic angle finder mounted directly to the strut body to set caster?
nbscooters |
Member ![]() ![]() Group: Members Posts: 165 Joined: 29-June 05 Member No.: 4,347 Region Association: None ![]() |
if you use the string method, you would need at least 3 people when you adjust the front; one to hold the steering wheel inside the car, one to adjust the tow underneath the car, and one to tell you the measurements from the wheel to the string.
i align 911's for post races. |
Mr.C |
Easy does it ![]() ![]() ![]() Group: Members Posts: 612 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None ![]() |
john rogers |
Yes. My rule of thumb is to set the top strut mount as far back as possible for the street, for stability. Set it forward for faster turn in or less camber. If you read the fine print in the article, it is for initial steup or in case of a off at the races and should not be used in place of a professional shop alignment for long term use.
Lo-Fi Version | Time is now: 29th April 2025 - 06:50 PM |
