Undrilled 914 rotors |
mharrison |
Sep 29 2003, 09:46 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
I am planning to drill rotors for 5-lugs. Does anyone have a source for 914 rotors that aren't drilled at all? I think there would be a great market for this, as well as 5-stud rotors for the 914. (Oh yeah, any source for these either)? I'm basically looking for a 5-lug with no holes.
-Matt |
Mueller |
Sep 29 2003, 09:56 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
if you can wait a week or so, I'll have pricing on a set of new hubs that allow you to convert to 5-lug and have 911 vented rotors without having to replace any other suspension component on the front...if you can replace front wheel bearings, then you can easily do this conversion.(uses 914/4 front wheel bearings)
(i know it shows 4-lug, but 5-lug is planned as well) (IMG:http://www.914world.com/bbs2/uploads/post-2-1064631459.jpg) |
Korijo |
Sep 29 2003, 10:25 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
DAMMIT !! Got to budget/generate more parts $$$
nebreitling |
Sep 29 2003, 11:52 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
bad ass!
are you making these yourself, or did you design them> nathan |
Bleyseng |
Sep 30 2003, 09:10 AM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
So what caliper will we have to run with that? Are you making spacer blocks for the stock calipers?
Geoff |
jdogg |
Sep 30 2003, 09:17 AM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Yeah, what he said....stock calipers?
mharrison |
Sep 30 2003, 10:04 AM
Let me know when these are available.
ArtechnikA |
Sep 30 2003, 10:07 AM
QUOTE(jdogg @ Sep 30 2003, 07:17 AM) Yeah, what he said....stock calipers? there is no lack of vented-rotor 911 'M' calipers... i think i've got a couple of sets, one for sure. another one if you count the set i'm taking off the 911 this winter to install aluminum 'S' calipers ... |
gklinger |
Sep 30 2003, 10:19 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
Mike, in 4 lug, will these be drilled for studs instead of threaded for bolts? I want to keep my 4 hole Mahles, but *really* want to go to studs.
Scott |
Sep 30 2003, 11:32 AM
Member Group: Members Posts: 208 Joined: 13-January 03 From: Redwood City, CA Member No.: 138 |
Mike,
Will I be able to bolt up late (steel) 911S calipers or would I need adaptors? How's my suspension coming? Not in a hurry just asking. |
Mueller |
Sep 30 2003, 11:43 AM
1)Calipers= still looking into this, a few options
*Stock with spacers *M calipers (available cheap, since the 911 guys upgrade to bigger units) (anyone have a set to loan me???) *Boxster Calipers *aftermarket calipers (not anytime soon, I want to focus on Porsche caliper alternatives first) 2)5-lug = studs only 3)4-lug = both studs and threaded versions are being looked at Scott, The middle of next week your suspension should be finished. Those calipers have a 3.5 inch spacing for the 911 struts, not too sure if they can be "tweaked" to fit the /4 struts. Do you have 914 or 911 struts?? |
Scott |
Sep 30 2003, 11:52 AM
Mike,
I have both sets of struts but heres the rub. The 914 ones are late ('76) and have the solid bottom. The 911 are 911T and have the split (pinch) bottom. I want to install the soild bottom ones for strength and safety. So...I can either wait for yours and hopefully put the steel 911S calipers on my late 914 struts or I will have to buy a new set of 911 struts (either late S or early Carrera). Thanks for the update on the suspension. |
ArtechnikA |
Sep 30 2003, 12:25 PM
QUOTE(Scott @ Sep 30 2003, 09:52 AM) ...I will have to buy a new set of 911 struts (either late S or early Carrera). Sportomatic cars came with aluminum calipers, so you have a few more options available. i used '69 911T Targa Sporto (!) struts on my /6 because they were the only ones with the combination of 3,5" caliper mount spacing and Boge top thread, so i could use my Boge-threaded externally adjustable Koni dampers... |
thesey914 |
Sep 30 2003, 01:26 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Mike, If your hubs allow 911 vented discs running on standard 914 wheel bearings then I reckon you'll have massive interest. (IMG:style_emoticons/default/cool_shades.gif)
Are these billet with all the spot facing machined for the studs? So the 911 "M" callipers have the same 3.5 bolt measurement as the stock callipers? |
ArtechnikA |
Sep 30 2003, 01:46 PM
QUOTE(thesey914 @ Sep 30 2003, 11:26 AM) So the 911 "M" callipers have the same 3.5 bolt measurement as the stock callipers? 911 'M' calipers have the same -3"- mounting centers as the stock calipers... 911 'S' and 'A' calipers use 3,5" mounting spacing... |
thesey914 |
Sep 30 2003, 02:08 PM
QUOTE(ArtechnikA @ Sep 30 2003, 11:46 AM) 911 'M' calipers have the same -3"- mounting centers as the stock calipers... Cheers for the clarification Rich (IMG:style_emoticons/default/beerchug.gif) |
Brad Roberts |
Sep 30 2003, 02:29 PM
Hum... sold exclusively thru.....
B |
fiid |
Oct 1 2003, 12:13 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
QUOTE(Mueller @ Sep 29 2003, 07:56 PM) if you can wait a week or so, I'll have pricing on a set of new hubs that allow you to convert to 5-lug and have 911 vented rotors without having to replace any other suspension component on the front...if you can replace front wheel bearings, then you can easily do this conversion.(uses 914/4 front wheel bearings) (i know it shows 4-lug, but 5-lug is planned as well) Killer Engineering Ninja Monkeys Do Exist!!! This is awesome, Mike! Good work. Fiid. |
thesey914 |
Oct 9 2003, 01:55 PM
*BUMP* -any progress??
Attached image(s) |
Brad Roberts |
Oct 9 2003, 02:01 PM
Scott,
If your following along at home on this... USE the 911 struts with the 3 inch bolt spacing. Anything else you use throws you into a totally different class with PCA and SCCA in our regions. Those pinch bolts have NEVER failed. Porsche switched to a different design because the ball joint supplier couldnt keep up with demand back then. You own a 4cyl car. Its doesnt need anything larger than a 911 M caliper/pads. B |
Lo-Fi Version | Time is now: 20th October 2024 - 03:28 PM |
