New rear bearing play.., How much play do these puppy's have? |
Andyrew |
Jun 16 2006, 08:26 PM
Just installed new ones... with the amount of play in these bearings... the rear susp would wobble just going down the street!!
Do they tighten up? or whats the deal? Do I need to get new one's? (IMG:style_emoticons/default/headbang.gif) |
SLITS |
Jun 16 2006, 08:31 PM
Did you pull/push the rear hubs into the bearing?
Joe Bob |
Jun 16 2006, 08:32 PM
Hubs and axles in? Castellated nut tight?
Aaron Cox |
Jun 16 2006, 08:41 PM
SKF's start suuuper sloppy. but they pull in tight.
Andyrew |
Jun 16 2006, 08:50 PM
Bearings where done by mike, using a press.
hubs in, axles not. Skf's.. Thanks Aaron.. No worries now. |
SLITS |
Jun 16 2006, 08:51 PM
Aaron Cox |
Jun 16 2006, 08:52 PM
SKF's start suuuper sloppy. but they pull in tight. MY FAGs are tight.......... thats how you like em... LOL andrew, eric put mine in my trailing arm with hubs... floppin all over the place... torque the stub axle nut to 240? or look it up... no more play |
Andyrew |
Jun 16 2006, 08:54 PM
Well.. you've heard it from slits... FAG's are tight!!
Anyways... I havent put the axles in yet.. so im sure with that in, it'll snug up good... If not... well... new bearing time. |
Andyrew |
Jun 16 2006, 08:55 PM
tq???? TQ??? I just jump on it a little with a breaker bar... (normally)
but... I think I'll try and tq them.. (240 sounds right)... Maybe I'll just have dad stand on the bar at X location... he's around 240........ lol |
PRS914-6 |
Jun 16 2006, 09:40 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
There are two halves to a bearing. Until they are squeezed together, they will be loose as hell. When you tighten them up with the stub axle, it will resolve the problem.
Lo-Fi Version | Time is now: 25th June 2024 - 11:32 PM |
