> Headlight "winks" forever !....
The Kelzer
post Jun 17 2006, 12:56 PM
(IMG:style_emoticons/default/WTF.gif)
Everytime I turn off my headlights, my left one winks several times or sometimes forever until I kill the power to it! Most of the time it doesn't stop in the correct location either....usually about 3/4 inch too high.
What gives ??
Mahalo,
Kelly
olav
post Jun 17 2006, 12:57 PM
Group: Retired Members
QUOTE(The Kelzer @ Jun 17 2006, 11:56 AM) *
What gives ??
Mahalo,
Kelly
Sounds like a flaky relay.
The Kelzer
post Jun 17 2006, 12:59 PM
[/quote]
How's that ?? Please explain.
KK
olav
post Jun 17 2006, 01:01 PM
On the headlight, under the plastic cover there is a relay. That might be bad.
The Kelzer
post Jun 17 2006, 01:03 PM
QUOTE(olav @ Jun 17 2006, 09:01 AM) *
Ok, I'm with you on that part....why do you come to that conclusion ? What triggers the relay ?
KK
dimitri
post Jun 17 2006, 01:13 PM
dimitri
Trigger is within the gearbox. You can open it and check for damage. Might need
some cleanning, most likely worn. Dimitri
Andyrew
post Jun 17 2006, 01:57 PM
Spooling.... Please wait
Quick check for the relay... is swap the relays side to side..... if the right side does it.. new relay time.
If not... its not the relays.
Andrew
DanT
post Jun 17 2006, 03:50 PM
Going back to the Dark Side!
Mine did the same thing and I found it to be due to a bad headlight switch...
I removed my relays to keep them from winking.
It is always a good idea to keep a couple of those round relays around a spares since they work on several circuits on the car.
(IMG:style_emoticons/default/sad.gif)
ClayPerrine
post Jun 17 2006, 04:27 PM
This should help you to understand how they work, and why they would keep running.
Classic message threads: How your headlight motors work.
- Lo-Fi Version Time is now: 4th January 2025 - 07:59 PM
