gepetto143 |
Newbie ![]() Group: Members Posts: 19 Joined: 5-December 05 From: Quebec city, Canada Member No.: 5,238 ![]() |
Is the clutch disk on my 74 1.8L the same as on 1.8L westfalia?
thank you Louis |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
I cant answer your question truthfully, but I would suggest the 6 spring 911 disc for your car. The 4 spring discs tend to rub on the flywheel bolts after having the flywheel turned. The 6 spring wont hit them.
B |
gepetto143 |
witch year of 911 clutch disk shoud I use?
Brad Roberts |
Let me get you the part number. Hang on.
It is for a 68-72 911 Stay with me. B |
Brad Roberts |
901-116-014-00
68-71 Mid 72 they went to the 915 tranny. B |
gepetto143 |
thank you!
Brad Roberts |
I knew where you were going with the Bus question.
Get the correct parts. You'll be fine. Pelican carry's them/GPR.. blah blah.. Typically Porsche parts places will understand if you ask them for the "6 spring disc" for the 914. B |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
No, difference clutches
Lo-Fi Version | Time is now: 26th June 2024 - 01:27 AM |
