how do I take my stock, steering wheel off? |
Sinner914 |
Jun 24 2006, 03:50 PM
Newbie Group: Members Posts: 31 Joined: 6-June 06 From: Del Mar, CA Member No.: 6,170 |
I feel like an idiot for even asking but how do I take the stock wheel off. Does the center piece just pop off with force or what? Quick tip would be great. (IMG:style_emoticons/default/confused24.gif)
elwood-914 |
Jun 24 2006, 04:13 PM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
It's been quite awhile but you take the horn section and spin it I think counter clockwise?? It should just pop off then.
Tim |
Cap'n Krusty |
Jun 24 2006, 04:25 PM
Push in a little on the horn pad, rotate it about 15-20 degrees, lift it gently off. Later cars have a wire, so exercise caution. Under there is a 27mm nut and a washer. Remove them. The Cap'n
736conver |
Jun 24 2006, 04:48 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Push in a little on the horn pad, rotate it about 15-20 degrees, lift it gently off. Later cars have a wire, so exercise caution. Under there is a 27mm nut and a washer. Remove them. The Cap'n The wheel might take a little convincing to come off so leave the nut on alittle. That way when you pull the steering wheel off it doesnt bonk you in the face. |
Sinner914 |
Jun 24 2006, 06:24 PM
thanks fellas, everything all good!!!! New momo monte carlo looks sweeeeeeeet!!!!
elwood-914 |
Jun 24 2006, 08:33 PM
Lo-Fi Version | Time is now: 4th January 2025 - 08:57 PM |
