scottb |
who wants a PEZ?! ![]() ![]() ![]() Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States ![]() |
take a look at the pics below. the window on the drivers side doesn't go all the way to the roof line. door seems to be in good alignment. car doesn't sag from rust. i haven't torn into the door yet, just looking for input before i do. thanks....
scottb |
nuther...
scottb |
last one....
thanks in advance... |
scottb |
shit....here's the pic...
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,711 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
what year is your car?
i only know early cars (door-wise). on the early cars, you have a adjustement srew on the bottom of the door for the window height (the one in the middle). you'll need a flat-blade screwdriver and a wrench, i think it's a 10mm (or was it a 13?)... there's a stop inside the window regulator that you move up/down with the screw. make sure you don't give it too much room, otherwise you can crack the plastic on top of your front triangle window if you put too much pressure on the crank. there are 2 more adjustements on the bottom, both adjust the window left/right in the front and the back. Andy |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
If you have late type window system there is an adjustable stop (10 mm headed bolt). It will be obvious once you remove door panel and roll window up. Not sure about early style but there must be something to adjust.
Porsche Rescue |
Guess with Andy's post and mine all bases are covered. Not sure if "late" doors begin with '72 or '73 but it is one or the other.
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
Late doors start in 73; mid 73 started door impact beams.
scottb |
thanks gents.... that and changing the oil/transaxle will provide the weekend projects!
Lo-Fi Version | Time is now: 28th June 2024 - 10:43 PM |
