Stieve |
Senior Member ![]() ![]() ![]() Group: Members Posts: 587 Joined: 6-May 06 From: Sacramento Member No.: 5,996 ![]() |
I put a test light on the top portion of the fuse and click on high beams, and the test light went on and off, high beams didn't illuminate, is it a bad relay? I can hear it click, and BOTH high beams don't light up, nor does the fuse stay hot when engaged. HELP!
Stieve |
zen motorcycle |
almost not a newbie ( way less than a newbie) ![]() ![]() Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None ![]() |
I had the same problem on my 73, Probaly not the smartest thing, but I switched the High beam and low beam connectors on the relay and everything worked. I assume it was from corrosion on the connectors, but I don't want to try switching it back now to find out. Have you messed with any of your wiring recently?
Stieve |
no, only tested the fuse ane the light bulb connection
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Bad TS switch or dirty contacts in switch. The 911s in 72-73 were notorious for ruining these switches.
Stieve |
Bad TS switch or dirty contacts in switch. The 911s in 72-73 were notorious for ruining these switches. Well Depending how fricken HOT it is tomorrow, I will tear into the column, since I have new switches and bearings and a Dino wheel to install as well as my Cold air intake. I will let you know. |
Chogokin |
Member ![]() ![]() Group: Members Posts: 173 Joined: 17-April 06 From: Pensacola, FL Member No.: 5,878 ![]() |
I had a similar problem, turned out to be the easiest thing for me.. one of the wires busted off of the plug on the back of each headlight. Not sure how but I found it when I was putting in the new headlights I got to fix the problem... should have checked it first I guess. Moral of the story, make sure to check the simple things before busting into the big stuff! (IMG:style_emoticons/default/biggrin.gif)
Stieve |
I will know more tomorrow, got into it, and decided to do the electric wiper wash install. I also swapped the HL switch, noticed #56? id disconnected(recheck number), is there suppose to be one missing on a 73?
Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
when my car had the exact same symptoms, it turned out to be the relay on the fuse block. I happened to have one, but i bet a VW one would work, it did for my turn signals
HeloMech |
Go Ahead, Get Pistoph! ![]() ![]() ![]() Group: Members Posts: 691 Joined: 31-August 05 From: Roy, WA Member No.: 4,718 Region Association: Southern California ![]() |
when my car had the exact same symptoms, it turned out to be the relay on the fuse block. I happened to have one, but i bet a VW one would work, it did for my turn signals OK, I've been going through this same thing... sorta. I had driving lights and high beams, no low beams. So, I took all the fuses out and cleaned, rebent the holders. I took all the wires off the fuseblock, one at a time and cleaned the connections, I took off the ground wires near the headlights and cleaned the mounting surface and connectors... tried the lights. NOTHING.. lol. Tonight I messed with that square silver relay on the relay board under the dash. I turned the lights on.. high beams worked fine. I clicked the switch, felt the relay click over. No lowbeams. Now I wiggled the wires on the relay.. .HAY! my lowbeams just flashed. so I wiggled that one wire again... which on mine was the white wire. it works. I leaned the wire over and taped it to the side (just to keep pressure on it) and I have both headlights now. I'll try to find a new relay this week. I don't drive in the dark anyway.. but, that's where I found my problem. Now, if I could just get my headlights to CLOSE when I turn them off... |
Lo-Fi Version | Time is now: 25th June 2024 - 10:51 PM |
