Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
So, I finally have time to work on my car (customer and school stuff all done now) so I decided to take another shot at my fuel problems. I ordered a long 3mm allen wrench to adjust the mixture, but I could not get the adjuster to move. The hole seemed bigger which later turned out to be because it is coned to help facilitate the entry of the allen end into its mark.
So, what did I do? I removed the whole dang assembly that houses the air plate and proceeded to remove the adjuster arm. Now time for some back ground: When I got the engine with the CIS there was a little red hose, from a can of WD40 can or something similar, sticking out of the air intake sleeve. In this set up the engine should have run leaner as this lets more air in AFTER the fuel regulation circuit. Currently: So I removed the adjustment screw arm and what I was suspecting to find, I did. The adjust screw was adjusted all the way rich. It was also caked with dirt so much that it couldnt be adjusted (probably why they put the extra air bypass in). I cleaned it, installed it, adjusted and tried to start it. Adjusted. Adjusted and now the throttle response and starting are much easier. Now it feels like the timing is off. That will be the next episode. I am pretty happy to have gotten this part of the problem sorted. Thanks to everyone who gave me insite into the adjusting of the CIS. (IMG:style_emoticons/default/biggrin.gif) |
krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
Let me ask a really stupid question, (IMG:style_emoticons/default/huh.gif) but I ASSume that you've got the CIS on a six?
Did the block riginally come with CIS or did you add it on? If you added it on, please let us know how you did it! Thanks! Konrad 72/4 P.S. Have you blown up the airbox yet? (IMG:style_emoticons/default/laugh.gif) |
Dr Evil |
It is the 2.7 /6 in my sig line that came out of a '74 and originally came with CIS. If you want to adapt CIS to a /4 do a search as the topic has been discussed with in the last 3 mo. I know ejm has one converted.
914efi |
Member ![]() ![]() Group: Members Posts: 140 Joined: 14-June 04 From: Westport,MA Member No.: 2,204 Region Association: None ![]() |
Order or borrow the correct pressure guage to be able to check fuel pressure and control pressure($50.00 ebay). If it has been sitting for a long time the FD might have problems. If you are pretty good with small mechanisms don't be afraid to take apart the control pressure regulator to clean. Just be careful. Is it a lambda system with o2 sensor?
Dr Evil |
'74, no lambda. I already took care of the rest of the system (other posts), this was the last basic adjustment. Now I get to fool with the dizzy (IMG:style_emoticons/default/blink.gif)
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I was lucky, when I installed the SC 3.0 engine I purchased off Ebay and fired it up it ran perfect, I never touched a thing adjusted or timed the engine, all was good. Then I started to F--- with it, slapped a turbo on it and a fuel enrichment injector a boost timing retard ignition and it still ran great never adjusted or timed it, I take that back I did adjust the valves. The bad news came when the oil pump sucked up a chunk of something, now I sit and wait and throw money at it in hope that it will run as it should but I highly doubt it will, WCC will come and go and I wont be there, the engines so cobbed together I am sure everyone will hear about it good or bad, hopefully by Fall.
I am hoping for the best maybe I will get lucky. Good luck Evil one. |
Dr Evil |
If it wasn't originally F-ed up I wouldn't have been able to afford it (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 11:15 PM |
