banksyinoz |
finally getting back into it ![]() ![]() Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand ![]() |
(IMG:style_emoticons/default/headbang.gif) what is goin on here
Attached image(s) ![]() |
banksyinoz |
ive seen rust before but this doesnt make sence
no rust on the inside has anyone attacked this before and how bad does it get all info would be appreciated does a yellow car mean its a lemon cause its startin to look like it |
banksyinoz |
inside pic
TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
Well, its a yellow car with a black engine bay, meaning that the enigne bay was probably painted black... To cover up rust (IMG:style_emoticons/default/smile.gif)
Chances are that the rust went through and some previous owwner painted over it. Thats a very common place for rust as the battery acid mixes with water and rusts away the wall and the hole at the bottom. I had rust in my car, same places, almost exactly the same shape, etc. I would strip that paint off and see what is really going on. -Tony |
banksyinoz |
thanks tony the battery solution fits the problem, the car was painted about seven years ago, so its a cut and weld solution
thanks |
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
Mine has rust in exactly the same place. Lots of cars have to have this panel welded
Lo-Fi Version | Time is now: 24th June 2024 - 07:17 AM |
