41ghost |
Member ![]() ![]() Group: Members Posts: 235 Joined: 13-July 04 From: noblesville,in. Member No.: 2,345 ![]() |
just like the discription says. what is the offset of rims it will accept without, or with spacers [5 bolt ] and with fender flairs. 16, 17 18" . i was looking at 18' with 8.5 52mm front, and 10" 58mm ofset, not sure if these will fit.
Bigbohr |
Superlurker ![]() ![]() Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 ![]() |
You're gonne need some massive spacers with these late offset wheels. Find out first the price of good +/- 2" spacers before buying the wheels. Eventually you will have to do fitting before getting the spacers (sorry for pointing out the obvious). You can use the following as an indication what you may need. There are plenty of other threads on this - do a search.
I have 275/17-40 tires in the back and still need a 6mm spacer with the 15mm offset rims I have (the resulting offset is 9mm). IMO you're not gonne fit much more tire than that under GT flears in the rear. For the front I have 235/45-17 tires and I need a 20mm spacer to fill up the GT front flair with my 23mm offset rims (the resulting offset is 3mm). |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
You're gonne need some massive spacers with these late offset wheels. Find out first the price of good +/- 2" spacers before buying the wheels. Eventually you will have to do fitting before getting the spacers (sorry for pointing out the obvious). You can use the following as an indication what you may need. There are plenty of other threads on this - do a search. I have 275/17-40 tires in the back and still need a 6mm spacer with the 15mm offset rims I have (the resulting offset is 9mm). IMO you're not gonne fit much more tire than that under GT flears in the rear. For the front I have 235/45-17 tires and I need a 20mm spacer to fill up the GT front flair with my 23mm offset rims (the resulting offset is 3mm). what is the width of your rims, that would help (IMG:style_emoticons/default/smile.gif) how is the turning effort? I'll be installing 245/17s on 8's on all 4 corners and was told that the turning effort is going to be a PITA at low speeds |
Bigbohr |
what is the width of your rims, that would help (IMG:style_emoticons/default/smile.gif) how is the turning effort? I'll be installing 245/17s on 8's on all 4 corners and was told that the turning effort is going to be a PITA at low speeds It does? (IMG:style_emoticons/default/blink.gif) Wheel offset and tiresize should tell the story. Anyways, its 17 x 7.5 front and 17 x 9 rear. I'll find out how the turning effort is when I manage to get the car on the road. In the garage it seems ok but that's prolly not a very good reference. |
41ghost |
what kind of wheel s do you have . can you show a pic of what your set up is. sounds like what i'm looking at is not a good set up .
Lo-Fi Version | Time is now: 24th June 2024 - 11:21 PM |
