bam914 |
Member ![]() ![]() Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None ![]() |
When boring and honing 914 cylinders shoud you use a torque plate or not?
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
You must use one.
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Mandatory....!!!!!!!!!!!!!!!!!!!!!!
Twystd1 |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Its a must, or you'll end up with a huge taper in the bore...
Blake, I can save you a LOT of trouble and guesswork! |
bam914 |
I was 99% sure I had too. Jake I need to get some work done on the block. When is a good time to call you?
Lo-Fi Version | Time is now: 20th June 2024 - 09:19 AM |
