> Hood hold down pins like on the race cars, Where, how, etc?
Dr Evil
post Aug 20 2006, 03:17 PM
Send me your transmission!
I have no locking mechanism for my engine lid and have seen (I am pretty sure I have seen this) in the past where people have use lock down pins to hold them down.
Mostly I see the pins on racer cars and mustangs and such. They are the type with the pin that goes throught the stud that goes through the trunk/hood/or engine lid.
Anyone have anidea where to get, and how to install? Any alternitive ideas? Was my description clear as mud?
Back to hematology.........
So.Cal.914
post Aug 20 2006, 03:26 PM
"...And it has a front trunk too."
If there was no place to mount the pin we would add a gusset to the corner
(under hood) and mount the pin there. Used to get them at a speed shop.
URY914
post Aug 20 2006, 03:28 PM
Try a race car suppplier like Truesports, Pegasus, etc
http://www.pegasusautoracing.com/
http://www.essexparts.com/index.shtml
http://www.racerwholesale.com/index.php
jonwatts
post Aug 20 2006, 03:31 PM
no rules, just wrong
I like the ones they used on the GT car engine lids. They had a catch that slid over the pin to capture it. I think there were pictures from the pbase site.
Am I helping?
Jeroen
post Aug 20 2006, 03:36 PM
Region Association: Europe
you're local race shop should have quite a choice of hood pins
if you can't find anything local, Pegasus usually has what your looking for (or some other online race shop)
I'm leaning toward Dsuz sliders
These slide over a small barrel, they're a lot smaller and more subtle than regular hood pins
(IMG:http://www.pegasusautoracing.com/Images/M/3009.JPG)
Pip pins are also nice!
Eric_Shea
post Aug 20 2006, 03:39 PM
PMB Performance
Got mine years ago at Pegasus. Might want to try Summit as well.
TimT
post Aug 20 2006, 03:42 PM
retired
These ones are flippin sweet
Dr Evil
post Aug 20 2006, 03:45 PM
Wow, more options than I expected! Awsome! Thanks. I like the Dzus type. I am planning on putting them onto where the little rubber pads are now fo rthe engine lid. I am looking for the cleanest, easiest solution.
Thanks fellers.
jonwatts
post Aug 20 2006, 03:47 PM
QUOTE(Jeroen @ Aug 20 2006, 02:36 PM) *
Yeah, like those.
Jeroen
post Aug 20 2006, 03:48 PM
QUOTE(TimT @ Aug 20 2006, 11:42 PM) *
yeah, they are
if only they were a little bit cheaper (insert CSOB smiley)
keep in mind he's looking for something to hold his engine lid
URY914
post Aug 20 2006, 03:57 PM
These are by Moroso on my front trunk...
Dr Evil
post Aug 20 2006, 04:40 PM
Oh, thats how they go on. I was thinking of mounting the plate vertically on the piece that the rubber nubs sit atop and mounting t he clip part facong down vertically. I guess I would then have problems unlocking them, huh? (IMG:style_emoticons/default/blink.gif)
Dr Evil
post Aug 20 2006, 04:44 PM
For the sites you guys posted, what is it called that I am searching for?
I think the PIP type would be the easiest to adapt next to the original pin idea.
Jeroen
post Aug 20 2006, 05:16 PM
the ones pictures are called "Dzus 1500"
check the paragon site > hardware > quick release fastners
Dr Evil
post Aug 20 2006, 06:20 PM
Cool, thanks. I searched Dzus which turned up the 1500 already. Very inexpensive, but not sure if it will be an easy placement. Pins, or PIPs may be the ticket. I need to search and measure.
"quick release fasteners"
ws91420
post Aug 20 2006, 06:39 PM
Yes I have one a Lensley 914
From: Ruther Glen,VA (halfway between sticks and civilization)
Local Hot rod shop or drag car buildrs should have them in stock also
Also some FLAPS carry the big pin type that you think of for muscle cars
iamchappy
post Aug 20 2006, 06:41 PM
It all happens so fast!
Im using the Moroso ones on my engine lid, I didnt like the pointed end so I filed mine
flat.
Dr Evil
I am in an autoparts desert out here. I wonder if there are anyspeed shops. No hurry, it doesnt even run yet. (IMG:style_emoticons/default/dry.gif)
Did you get your shift rod together?
JPB
post Aug 20 2006, 07:14 PM
The Crimson Rocket smiles in your general direction.
Hey local brother. I think what you are looking for are "hood pins". They are the standard hood safety pin and clevis type. The above Pegasus site has them under this heading. Hope ya find them and hope to see ya at the ECC.
(IMG:style_emoticons/default/beer.gif) Gluck
alpha434
post Aug 20 2006, 08:11 PM
My member number is no coincidence.
Search EBAY for "hood pins." Ricers love that crap, so there is a TON of it for cheap. I just bought four for my f/g rear trunk for 4 bucks. I've also seen KEY locking ones for cheap too on ebay.
- Lo-Fi Version Time is now: 27th December 2024 - 03:08 AM
