Door question..., checking curves.... |
crash914 |
Aug 23 2006, 05:55 AM
its a mystery to me Group: Members Posts: 1,828 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
all--
In checking the doors, I only had a 4 ft. straight edge... Front and rear align with the door edge, but there appears to be a curve to the door front to back. Is this the case? it is very slight and I am sure that I can blend it so it is smooth. This door had been hit and creased in the lower rear. plenty of filler later, the front and rear match up pretty good. i am also blending in flairs also. can someone run out and check with a 6 foot straight edge? many thanks.... see picture for before.... Attached image(s) |
URY914 |
Aug 23 2006, 06:31 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,254 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
After making several sets of fiberglass doors, I can tell you they are not straight. There is a curve to them. Hard to see really.
Paul |
thomasotten |
Aug 23 2006, 06:41 AM
Senior Member Group: Members Posts: 1,556 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I have been getting mine ready for paint, so I have been sanding mine with a 4' level. I find that they are pretty much straight, but all the panels seem to curve in a bit when you get near the edge or seem. I think that is due to the way the metal was stamped out.
crash914 |
Aug 23 2006, 04:25 PM
Thanks!
I saw the slight bow also and was wondering if I should sand it out... I think I will leave it in... |
Lo-Fi Version | Time is now: 27th December 2024 - 04:41 AM |
