Repairing outer door handle, All or flapper? |
BigDBass |
Aug 24 2006, 09:47 AM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
Hi,
My passenger side outer door handle is broken. It's the "mounting flap" that is cracked. I can still open it by sort of pushing the door while I pull the latch. It looks basically like this pic from pelican: (IMG:http://www.pelicanparts.com/techarticles/914_door_handle/914_door_hanldle_pic5.JPG) Do I need to replace the entire handle, or will just a "flapper" suffice? Thanks. |
ptravnic |
Aug 24 2006, 09:53 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
Common problem - you'll need the part the key goes into but there's a guy somewhere on the site that repairs them. Check out the Pelican how to article - good step by step instructions.
-pt |
mihai914 |
Aug 24 2006, 10:07 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Click HERE it will bring you to the ressource section and more specifically the person who can repair yours I think...
BigDBass |
Aug 24 2006, 10:18 AM
Yeah, I was planning to follow the Pelican Parts article and fixing it myself.
I am getting a few parts from a member here and need to determine if I should get a complete used exterior door handle, or just a used "flapper". I'm not too sure what exactly the "flapper" part of it is. So, it's simply a multiple choice question! (IMG:style_emoticons/default/smile.gif) Thanks! |
mihai914 |
Aug 24 2006, 10:22 AM
This is the flap, no longer available from pelican.
Attached image(s) |
Joe Ricard |
Aug 24 2006, 10:26 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Contact Paul (URY914)
I know he fixes them and has some because I just sent him a couple. |
URY914 |
Aug 24 2006, 03:42 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,268 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You have a broken mounting tab. Replacing the "flapper" won't help you. They are two different pieces.
Send it to me and I can fix it. Go to my blog for a complete story of the outside door handle. Paul |
Lo-Fi Version | Time is now: 27th December 2024 - 09:51 AM |
