type4org |
You need PLAID! ![]() ![]() Group: Members Posts: 231 Joined: 13-June 06 From: Oldenburg (Oldb), Germany Member No.: 6,212 ![]() |
For what it's worth, turns out that the 165SR15 tires the previous owner bought before I purchased my '76 are all out of round. Those are new Nankang tires, and unfortunately the chain where they were bought (Les Schwab) only exists on the west coast (I'm in VA now). Buyer beware...
I'm looking for replacements (probably repros from Coker Tire this time) and a set of original steel wheels. Hey, anyone on the VA are have a set of *good condition* steelies? Trade you a set of Rivieras or buy outright (IMG:style_emoticons/default/smile.gif) |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Michelin still has old school tyres. Look at their Euro web site. T |
ws91420 |
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region ![]() |
Hey I work for a tire place and will check on Thursday what we can get.
type4org |
Hey I work for a tire place and will check on Thursday what we can get. Which place? I went to NTB in Central park thinking it was a balancing issues - those guys were really nice, didn't charge me a dime when they noticed there isn't much they can do with a balance job. |
ws91420 |
Merchants in Stafford same company.
type4org |
Merchants in Stafford same company. If they don't have good brand name tires available, can you find out if they can order from Coker Tires? And how long it would take? If I can find a set of steelies in the next few weeks I'll be happy to swing by and have it done at Merchants. |
ws91420 |
Will do when I work on thurs. May check tomorrow if I am up that way.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Cooper has a good 165 tire.
They don't crack all to hell like the Michelin |
r_towle |
the tires are probably ok.
The rims, rivieras specifically, are not hub centric...therefore you cannot put them on a machine that centers the wheel using the hole in the middle. most machines do this. You need to go to a well equipped store, typically the old timer tire stores, or the new dealer shops. These shops have the correct jig that is the same bolt pattern as the 914/vw bolt pattern. This mounts to the wheel using the lug bolts, and then to the machine. The fuch alloys are the only ones I have had that are hub centric and lug centric at the same time...so the wheels are not out of round, nor are the tires...you just need to go to a good shop or a VW delaer that has a tire machine. BTDT two 914's and a super beetle The super is the most senstive front end on earth..it took a long time to fix this issue, when all along it was just the guys using the wrong machine... rich |
type4org |
the tires are probably ok. The rims, rivieras specifically, are not hub centric...therefore you cannot put them on a machine that centers the wheel using the hole in the middle. most machines do this. The symptom, a shake at speeds over 60 mph, persists. I wouldn't even know where to look for (or even have the time to look for) a shop that has more specialized equipment. It's my goal to replace the Rivieras, anyway. |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
OH!!!!!
This is why my tires are NEVER in balance!! |
ws91420 |
the tires are probably ok. The rims, rivieras specifically, are not hub centric...therefore you cannot put them on a machine that centers the wheel using the hole in the middle. most machines do this. The symptom, a shake at speeds over 60 mph, persists. I wouldn't even know where to look for (or even have the time to look for) a shop that has more specialized equipment. It's my goal to replace the Rivieras, anyway. Will check if we have the adapter to do that Jens. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:50 AM |
