OT. Stereo Electronics Gurus, My home stereo has a buzz |
Brett W |
Oct 26 2006, 08:22 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
When I turn my stereo I get a low level hum/buzz. How do I get rid of it? My system is a few year old Pioneer rack system. Nothing special.
jimtab |
Oct 26 2006, 09:07 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
mine did that when my ground on the turntable was screwed up...after that ?????
McMark |
Oct 26 2006, 09:12 PM
Ground loop problem. Search for ground loop on google.
ahdoman |
Oct 26 2006, 09:33 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Ground loops can be a pain to trace. There are two most common problems that create the hum besides ground loops. The first is wall warts and other power supplies. Don't run your power cables bunched up with your line level (hopefully shielded) cables. Second is make sure you are not using unshielded cable for your component interconnect. E.G. use shielded between your CD player and tuner / amp. Make sure you only use speaker cable for speakers.
So.Cal.914 |
Oct 26 2006, 09:58 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I had a capacitor go bad on my BGW 750-A rack mount amp and it developed a hum,
replaced it and it's now clear as a bell. |
Lo-Fi Version | Time is now: 15th January 2025 - 05:14 AM |
