Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Need some help. (IMG:style_emoticons/default/sawzall-smiley.gif)
I bought the CB throttle linkage, but it isn't going to work with the TWM throttle bodies, without a lot of fabrication work. (IMG:style_emoticons/default/mad.gif) I don't know of anyone who is running TWM's on a T4, so we are plowing new ground again. So who out there makes a throttle linkage (set) that is easily adaptable? You'd think it would be easy to find, but it is exactly the opposite. Finding something that is adaptable will be worth a lot to us as we are running out of time. Thanks |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
call jake...
he runs jenvey's and probably TWM's too... |
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
DTM Butterfly linkage
But you're not running DTM are you? I have 1, maybe 2, old-school butterfly links around. Let me rummage. |
Randal |
DTM Butterfly linkage But you're not running DTM are you? I have 1, maybe 2, old-school butterfly links around. Let me rummage. No DTM, correct. If you find anything please let me know. |
azbill |
Member ![]() ![]() Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region ![]() |
I'm using this on my Jennvys
Hope this helps Bill Shaffer Attached image(s) ![]() |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Gotcha covered..
Bout 100 bucks, stainless steel and ball bearing supported.. Here it is on a 2316 with TWMs, I even have the correct adaptors for the TWMs- not even they have them.. (IMG:http://www.aircooledtechnology.com/customers/gwanegar/vert%20033.jpg) |
Randal |
Gotcha covered.. Bout 100 bucks, stainless steel and ball bearing supported.. Here it is on a 2316 with TWMs, I even have the correct adaptors for the TWMs- not even they have them.. (IMG:http://www.aircooledtechnology.com/customers/gwanegar/vert%20033.jpg) Looks good Jake. Do you the assembly available now, including the TWM adapters? Thanks again... |
Jake Raby |
I **think** so...
I don't use them too often because most of my engines run the DTM.. I'll check tomorrow.. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
group discount for 3 linkages?? (IMG:style_emoticons/default/smile.gif)
I've got 2 sets of these m/c throttle bodies...just need to decide what/how to do the aircleaners and linkage.... ![]() |
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
Linkage photos on TWM's:
Attached image(s) ![]() ![]() |
ottox914 |
More linkage- got mine thru Jake, sort of- he was busy and didn't have it on the shelf, so he sent me to the supplier to get one directly to get me on the road faster.
Some posted about the possibility of unstable idle as the engine heated and expanded, but I have had no such issues with this system. We did need to fab a mount for the factory cable to attach to. I added a hole and grommit in the engine tray, not the engine tin, so if/when the motor needs to be dropped, I just disconnect it from the central barrel, and it will be kept out of the way by its routing thru the tray. Attached image(s) ![]() ![]() |
Randal |
More linkage- got mine thru Jake, sort of- he was busy and didn't have it on the shelf, so he sent me to the supplier to get one directly to get me on the road faster. Some posted about the possibility of unstable idle as the engine heated and expanded, but I have had no such issues with this system. We did need to fab a mount for the factory cable to attach to. I added a hole and grommit in the engine tray, not the engine tin, so if/when the motor needs to be dropped, I just disconnect it from the central barrel, and it will be kept out of the way by its routing thru the tray. That is a very clean installation. Thanks for the pictures |
Jake Raby |
My new filter stacks for TWM and Jenvey T/B's....
(IMG:http://www.aircooledtechnology.com/galleries/fall06rd/Filters,velocity%20stack%20017.jpg) These babies are making incredible power- hell they should after over a year of trying different things for my EFI engines.. On a MassIVe power plant of 2270cc (IMG:http://www.aircooledtechnology.com/galleries/fall06rd/Filters,velocity%20stack%20016.jpg) Data from initial testing atMy forums |
crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
Hey Jake,
would this linkage work for Redline Weber throttle bodies? I like the fit of the throttle cable better than what I have.... |
ottox914 |
Jake- nice looking set up. That SDS hall sensor looks way to easy with your DTM, as compaired to the work to do it as I did with the OEM cooling. Where do you mount the intake are sensor? I ended up making an aluminum plate to block off the open center section of the CB performance air cleaners you sent with my TWM's, and drilling a hole in that plate for the sensor.
Lo-Fi Version | Time is now: 23rd June 2024 - 01:14 PM |
