zen motorcycle |
almost not a newbie ( way less than a newbie) ![]() ![]() Group: Members Posts: 259 Joined: 21-May 06 From: Dallas Member No.: 6,038 Region Association: None ![]() |
I got a rebuilt injector as mine was leaking and proceeded to install it. I got everything buttoned up and started to look at the old injector to see where it was leaking exactly
I don't see the tip seal (IMG:style_emoticons/default/sad.gif) Any chance it just disintegrated? I didn't feel anything like a seal while I was inserting the new one. If it was/is still in the injector hole what can I do Thanks |
Scott-thundercat |
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 ![]() |
none of my injectors had that on em. i know they should of but i couldnt find em either- it ran fine though.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
doesnt not running the inner injector seal cause sealing issues and vacuum leaks?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,587 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Yes, they will cause vacuum leaks if they are missing.
Go to O'Reilley's and get a set of injector seals from the help isle. They are for Japanese cars, but they fit a 914 just fine. |
zen motorcycle |
Yes, they will cause vacuum leaks if they are missing. Go to O'Reilley's and get a set of injector seals from the help isle. They are for Japanese cars, but they fit a 914 just fine. Let me make this clear I have the new injector installed in the car with a new tip seal. I don't see the old tip seal from the old injector I removed. Could it have been pushed into the cylinder? If so how to remove. Engine has not been turned over yet. |
zen motorcycle |
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
They do tend to stick in the manifold sometimes so I would check that. If it's not there, I would go ahead and fire it up. I doubt it would makei t into the cylinder and, if it did somehow, it probably wouldn't be disasterous. It's only rubber.
My car had two seals on a couple of the injectors - probably from the PO not noticing they stayed in the manifold. Hope this helps. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:09 AM |
