Removing the rear valence on a '74 2.0, Must I remove the rear bumper first? |
Lavanaut |
Nov 12 2006, 02:00 PM
Hungry Mind : Thirsty Gullet Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
That's what it's looking like to me, but would like to confirm.
Thanks |
So.Cal.914 |
Nov 12 2006, 02:10 PM
I have never had to remove the bumper to R & R a valence.
Bruce Allert |
Nov 12 2006, 02:20 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
There's a few screws going into the body... that's all.
.....b |
Lavanaut |
Nov 12 2006, 02:42 PM
Hmmm...I'm confused then. I removed the two sheet metal screws on the underneath, inside part of the valence and the four self-tapping screws on the outside. The valence won't budge though, it's not even loose...? (IMG:style_emoticons/default/confused24.gif)
Bruce Allert |
Nov 12 2006, 03:56 PM
IIRC it slides into position. Get a flashlight & look under the area where it is attached. There may be tabs that slide onto the body. You may need to push it forward or pull it back toward you. It's been so long since the last one I installed I can't remember for sure.
...b |
lotus_65 |
Nov 12 2006, 04:30 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
the fit on my bumper was tight and a little warped (the valance is wedged between the bumper and body panel on mine and i assume on others as well).
i had to loosen the bumper bolts to get her loose enough to slide the valance off. paul |
Lo-Fi Version | Time is now: 18th June 2024 - 07:50 AM |
