2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
As I tear into this 2.0 motor, I find three green injectors and one yellow...Are they different flows and should I go locate another green...Are they generally successfully cleanable and re-install...
2-OH! |
sechszylinder |
Member ![]() ![]() Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None ![]() ![]() |
hilow,
different color means different fuel flow rate. The green ones are for the 2.0 l d-jet engine whereas the yellow one belongs to 1,7 l engines. You have to use the green coloured injectors on your 2.0 l engine on ALL four cylinders !! benno |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
You should get all your injectors cleaned. That will improve the spray pattern and performance. Replace the tip seals while you are in there. DaveP |
Lo-Fi Version | Time is now: 25th June 2024 - 11:08 PM |
