sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
Just saw this video of some clear wheels.
http://videos.streetfire.net/video/be0f44f...86e003197c3.htm |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I wonder what would happen to the wheels after the brakes get really, really hot.
Ugh, look at the specs (heavy) and a mere 20K for a set. Technical Data The center is 1.5 or 2” polycarbonate, chemical hard coated both sides. Weight 20” - 27 lbs, and 22” - 38 lbs (complete wheel weight) All other parts of the wheel are forged 6061t aluminum (Inner and outer hoops and Hub center) SAE tested, certified and passed Impact, cornering and radial tests. Now in production, average delivery time is 6-8 weeks. Suggested retail is $5000.00 per wheel |
sj914 |
I don't think you can use them in a racing environment and yes I wonder what happens to them when it gets mounted to car that sees regularly red hot rotor temps. <insert melting smiley>
turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
TravisNeff |
You haveta put in the neon lights first, yo!
mrdezyne |
Now on larger rolling jack stands! ![]() ![]() Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 ![]() |
scratch that....
just watched the video, where are the wheels again? |
sj914 |
I wonder what would happen to the wheels after the brakes get really, really hot. Exactly what I was thinking. Might be kinda cool for a weekend drive to a night club but thats about it. Might be good on a Prius, since we all know who ever drives those things don't go past 25mph. |
sj914 |
ninefourteener |
Perfectly Normal Guy :) ![]() ![]() ![]() Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 ![]() |
Even if you have the $$$....... I don't
Even if you like the style....... I don't Why the hell would you want to remove the wheels every 3 weeks to clean them???? |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
How you say, LAWSUIT material (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 20th June 2024 - 06:29 AM |
