> Top rattles when I drive, Can it be adjusted?
chris914
post Nov 21 2006, 04:14 PM
Hi,
The back of top rattles when I'm driving down the road. Can it adjusted so it's tigther and wouldn't rattle?
IronHillRestorations
post Nov 21 2006, 04:36 PM
I. I. R. C.
One trick is to put a piece of vacuum hose over the latch pin on the roof. How are the seals?
william harris
post Nov 21 2006, 04:37 PM
914 Restorer
Well the rear latches can be adjusted on the top so they line up well with the latch mechanism. This is usually not a problem. This sounds like a problem with the rubber seals on the top - probably worn out.
HeloMech
post Nov 21 2006, 04:44 PM
Go Ahead, Get Pistoph!
QUOTE(9146986 @ Nov 21 2006, 02:36 PM) *
That's a good idea... though, I don't know if I can remember the last time I drove with the top ON the car.... (IMG:style_emoticons/default/piratenanner.gif)
chris914
post Nov 22 2006, 05:24 PM
The rubber hose worked good. Thanks! The seals are a little flat. Maybe some day I will replace them.
majkos
post Nov 22 2006, 07:06 PM
Dude! You live in Kalifornia, go TOPLESS!
Like Mrs K ! (IMG:style_emoticons/default/wub.gif) (From Henna of course)
chris914
post Nov 22 2006, 07:38 PM
QUOTE(majkos @ Nov 22 2006, 05:06 PM) *
My car is faster with the top and windows up.
http://www.cassidy-online.com/porsche914/a...aids/index.html
Porsche Rescue
post Nov 22 2006, 08:30 PM
Saving and Enjoying Old Porsches
If you continue to get a squeek/rattle from the rear of the top, remove it and lube the rectangular plastic blocks on the top that contact the targa bar.
I once drove 2000 miles while listening to the annoying rattle. Later learned that if I had inserted a piece of paper/dollar bill under the block it would have temporarily quieted things down. Lubing the blocks with a bit of grease/Vaseline does the trick.
Elliot_Cannon
post Nov 22 2006, 09:08 PM
Group: Retired Members
Put the roof in the rear trunk. If it rattles you won't hear it. LOL
Elliot
Howard
post Nov 23 2006, 08:54 AM
Incontin(g)ent Member
Folded towel on the targa bar. Adds positive ventilation and creates downforce. (IMG:style_emoticons/default/blink.gif)
TheCabinetmaker
post Nov 23 2006, 02:41 PM
I drive my car everyday
try some talc, or glycerine on the rubber seal. In a pinch, bar soap will work for a couple a weeks. Check the latches for wear.
Elliot_Cannon
post Nov 23 2006, 11:12 PM
QUOTE(Howard @ Nov 23 2006, 06:54 AM) *
Won't the flapping towel make as much or more noise than the squeeking top?
Elliot
SGB
post Nov 24 2006, 09:14 AM
just visiting
QUOTE(Elliot Cannon @ Nov 23 2006, 11:12 PM) *
Elliot
But you get that "scarf in the wind" look, like the famous ww1 fighter ace, Snoopy
Howard
post Nov 24 2006, 09:23 AM
Fold it, ya dorks. (IMG:style_emoticons/default/KMA.gif)
Elliot_Cannon
post Nov 24 2006, 08:26 PM
QUOTE(Howard @ Nov 24 2006, 07:23 AM) *
OK. So how many times do I need to fold the towel? Should I use a bath towel or a dish towel or a face towel? Should it be installed between the two roof latches or do I need to make holes in the towel?
Elliot
SGB
post Nov 24 2006, 10:10 PM
just visiting
I think Porsh has a golf towel in the LL Porsh catalog.
vertigo
post Nov 26 2006, 08:35 PM
I have used shrink tubing over the hook part of the latch. I tried vac. hose, but it was too tight then.
- Lo-Fi Version Time is now: 4th January 2025 - 06:08 PM
